Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-12-2001, 10:29 PM
chopper chopper is offline
chopper is starting off with a positive reputation.
Casting Numbers
Need some help from the experts. I have a 1968 F100 with what I was told was a 429. The camshaft spun a lobe. So, I dig into it and get to looking at the casting number on the heads: D3VE-A2A. So, I trot to my trusty experts on FTE and discover that these are 460 heads. This revelation forces me to assume some really wacked out yoga positions in the wheel well so that I might peer between the frame and the header and get the block casting number: D1VE 6015 A2. Again the experts say 460.
Bottom line:
a. Would some joker rebuild a 460 with 429 crank and pistons?
If so, why?
b. Could said joker be mistaken in thinking he was selling a 429 which in fact was a 460?
What do you guys think?
  #2 (permalink)
Old 05-13-2001, 03:14 AM
proud owner proud owner is offline
proud owner is starting off with a positive reputation.
Casting Numbers
Heres the story.
The 429 and 460 used the same block, same heads, same manifolds, same everything(unless CJ, SCJ, or Police engines).
The ONLY difference between the 2 were the crank and rods.
Your heads, D3VE, standard 429/460., late model, low compression emissions heads.
Your Block is a standard 429/460 block.
The only way to be sure it is a 460 or a 429 is to look at the crank. The 429 crank will say 4U or 4UA. The 460 crank will say 2Y, 2YA, 2YAB,or 2YABC.
Sure, some "joker" could rebuild a 460 block to a 429... Just to get a 429. Or, vice versa.. someone could turn a 429 into a 460... They are the SAME, except for the crank. Personally, I dont even know why they made the 429 in the first place!
Once again, said "joker" may very well have had a 460 and dint know it. The only way to tell is to check the crank.
Good luck! Hope it's a 460!!
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
  #3 (permalink)
Old 05-13-2001, 08:07 AM
Nathan Nathan is offline
Nathan is starting off with a positive reputation.
Casting Numbers
Dont be disappointed if it is "only" a 429. The shorter stroke makes them a higher reving engine, good for racing in light weight chassis. The 460s are better "pullers" with more low end torque.
Nathan
  #4 (permalink)
Old 05-14-2001, 12:21 AM
cobrajet cobrajet is offline
cobrajet is starting off with a positive reputation.
Casting Numbers
hi Chopper, just want to correct proud owner on one of his statements. (( the only difference between the 429/460 IS the crank and the pistons )) ... and NOT the crank & rods. just needed to set things straight...
  #5 (permalink)
Old 05-14-2001, 03:06 AM
mike460's Avatar
mike460 mike460 is offline
mike460 is starting off with a positive reputation.
Casting Numbers
__________________
88 F150
351 Windsor, Performer RPM Heads, Trick Flow R Intake, Lunati 51025 Cam, Comp Pro Magnum 1.6 Rockers, Hedman Headers, Custom Exhaust
http://www.youtube.com/watch?v=w3uQx7WVuVA
Tags
370 , 429 , 460 , 6015a2 , bb , big , block , casting , crank , d1ve , ford , location , number , numbers , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
