Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-05-2008, 07:09 AM
keepnbuzy is starting off with a positive reputation.
Superchip programmer question
I bought a Superchip about 4 months ago for the simple reason of gaining diesel mpg's. I've keep it on the middle setting (tow safe) for these 4 months and really don't notice a bit of increased milage.
The guy I bought it from said he always kept it on the top setting (preformance) and he got about 3 mpg better but I'm afraid to for the reason of I don't want to chance anything going wrong with this $$$$$ engine.
I drive it like an old lady 99% of the time but I find myself maybe once every 2 weeks stopping a sports car from thinking I'm slower then him because I'm big and stinky :-)
Question is: Should I go down to the economy setting or up to the preformance setting to see better MPG's and if leaving it on the Preformance setting but driving it nicely can do ANY stress on the 6.0.
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-05-2008, 09:22 AM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
I wouldn't recomend running it on a 6.0 at all
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #3 (permalink)
Old 02-05-2008, 09:38 AM
miller_feed's Avatar
Hook it, I'll pull it.
miller_feed is a name known to allmiller_feed is a name known to allmiller_feed is a name known to allmiller_feed is a name known to allmiller_feed is a name known to allmiller_feed is a name known to all
Thanks
Ray is right. Go down to the 6.0 fourm and you will see what they are all running on their trucks.
Welcome to FTE.
__________________
RICK, PAA MEMBER #4
Jim? Is it April yet?
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's filter cover, BTS-VB, DP-TUNER- stock, 40t, 60t, 80e, 140s, HI, OBA, 203*, billet housing, IH bolts, MBRP 4" SS, Isspro 3 gauge kit, Zoodad, Foil delete, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler. For now.
  #4 (permalink)
Wasn't really my question but thanks anyway
  #5 (permalink)
Old 02-05-2008, 09:42 AM
OK, My brother has been running the superchip on his 06', 6.0 for 2 years now. He keeps it in performance tune all the time because he does not pull anything. I ran superchip in my truck for 4 years and never had a problem with it. I thought it was fast untill I went to DP-TUNER.
Good luck.
__________________
RICK, PAA MEMBER #4
  #6 (permalink)
Old 02-05-2008, 09:52 AM
rbaker6336's Avatar
I ran the hypertec programmer on my 7.3 before I got the DP tuner and on the highest setting did get a minute mpg gain but nothing on lower settings
I would imagine the superchip s the same
__________________
Ray
'98 Grand Cherokee
PAA #35
  #7 (permalink)
Old 02-05-2008, 12:03 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
Welocme to FTE.
To an answer your question generally speaking your performance tune will give you the best milage, the key is to keep your foot out of it.
Miller_Feed is right though, you should check out the 6.0 forum, i think they could offer alot more tech info on your tuner.
__________________
Got beer ? 434HP 765 TQ
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,CUSTOM TUNING, SEIC IDLE MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #8 (permalink)
Old 02-05-2008, 01:49 PM
tex25025's Avatar
tex25025 is gaining momentum as a positive member of FTE.tex25025 is gaining momentum as a positive member of FTE.
Thanks
First off you'll see better mileage with the performance tune then you would with the economy, however you have to be able to drive it in an orderly and sane manor. Also the main purpose of any chip and/or flash tuner is to increase performance first(especially when you talk about the off the shelf ones, you can do more with a custom one, but your talking about an off the shelf one) and then mileage maybe(that's right only a maybe) an added benefit, but it is not promised. The best thing that you can do is drive it easy for the most part and every now and then allow the truck to stretch it's "legs" and have some fun or else you'll have problems with sticking turbo veins etc. Most 6.0 owners(myself included and I did come from where you starting from except I had BullyDog) would tell you it would be better to get rid of the tuner you have and get the SCT with custom tunes and the tunes can be written specifically with how you drive and what you want to accomplish with it and if you mod it further you can change the program(s) for that as well. I know it's not what you want to hear, but unfortunately alot of people have gone thru alot of problems to come to some sort of consesus for the 6.0 and that's pretty much it if you want to go down this way of using a tuner.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
SCT w/Spartan tunes(including FICM tuning)
Fuel Regulated Return
FASS 150/180
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
