Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 02-05-2008, 01:35 AM
Black Cowboy Black Cowboy is offline
Garage is empty, add now
Black Cowboy is starting off with a positive reputation.
Motor took a crap...I 'bout crapped my pants
Any body know of a good shop that rebuilds diesel engines? My motor went to ***** yesterday on Rte. 50 in Annapolis. She was running fine and then all of a sudden lost oil pressure and the rest is history...along with the motor. Any good recomendations would be greatly appreciated.
__________________
Jason
  #2 (permalink)
Old 02-05-2008, 10:59 AM
Surge08's Avatar
Surge08 Surge08 is offline
Just a Damn Number
2004 Ford F-350
My Garage
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
don't know anyone off hand
__________________
Chris
2004 F350 XLT 4x4 6.0L SC/LB 4x4
1998 Explorer Sport 4x4 4.0L
I am just a number and no I don't care about Trophy's
  #3 (permalink)
Old 02-05-2008, 12:16 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
2005 Ford F-250
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
How many miles ya have on it, Jason? How long did it run without oil pressure?
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family)
Join the Maryland Chapter click HERE
  #4 (permalink)
Old 02-05-2008, 07:55 PM
Quote:
The motor only has 140K miles. Which is surprising because any other 7.3 diesel I've driven has been bullet proof. The truck was orginally owned by a logging company and they had to put a new motor in it. They probably ran the orginal motor into the ground and probably beat the snot outta this one too. I purchased the truck from my uncle and he only used it to haul trash/junk. However, I did get a couple of leads through people at my work that will save me some money on a new motor. Ran for approx. 10 seconds w/out oil pressure. Spun a bearing maybe???
__________________
Jason
  #5 (permalink)
Old 02-05-2008, 09:35 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
In 10 seconds - I doubt it. I watched these things go for 15-30 minutes with no oil at all before ceasing up....and then after cooling off, start again!
__________________
  #6 (permalink)
Old 02-05-2008, 09:37 PM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
If it doesn't turn over, something broke inside!
__________________
  #7 (permalink)
Old 02-06-2008, 03:47 AM
I'm pretty sure something broke inside, 'cause it'll turn over but then it'll start knocking like an SOB.
__________________
Jason
  #8 (permalink)
Old 02-06-2008, 10:22 AM
BPofMD's Avatar
Old-Timer
2005 Ford F-250
Yup, sounds like a rod.....new engine time. Was the oil pressure running low for very long...like months?
__________________
  #9 (permalink)
Old 02-06-2008, 11:06 AM
Surge08's Avatar
Just a Damn Number
2004 Ford F-350
My Garage
could be a spun bearing, was it full on oil?
__________________
Chris
  #10 (permalink)
Old 02-06-2008, 07:32 PM
Quote:
Yep, oil level was full. I changed the oil about a month ago.
__________________
Jason
  #11 (permalink)
Old 02-26-2008, 11:28 PM
Tractor Boy Tractor Boy is offline
1979 Ford F-100
My Garage
Tractor Boy has a good reputation on FTE.Tractor Boy has a good reputation on FTE.Tractor Boy has a good reputation on FTE.
I'll rebuild it................... it'll give me a project and something to do
  #12 (permalink)
Old 02-27-2008, 08:03 PM
Quote:
I'm all for it, but I was told that the 7.3 diesels can't be sleeved and therefore can't be rebuilt. If you know anything different please let me know.
__________________
Jason
  #13 (permalink)
Old 02-27-2008, 08:10 PM
1979 Ford F-100
My Garage
i'll look into it for ya and get back to ya with a better answer, I may be able to bore it...........
  #14 (permalink)
Old 02-28-2008, 03:45 AM
Thanks man
__________________
Jason
  #15 (permalink)
Old 03-13-2008, 02:27 AM
immastrokinnow's Avatar
immastrokinnow immastrokinnow is offline
immastrokinnow is starting off with a positive reputation.
a 7.3 should shut off before any real damaged is caused because of the fact its a huei. it needs oil to feed injectors. no oil, no fuel, no run. but the 7.3 cannot be sleeved. but it can be bored. check with blackwidowdiesel. they have rebuild kits and stronger rods too.
__________________
1977 f150 custom
lifted and on 35s
460 c6 combo from 84
9inch rear d44 up front
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
