Cab Light Template
Originally Posted by 00Dave
Thanks ron01sd. I called 2 Ford locations locally and they don't know of any template. I also thought that the wire harness went down the pass. side to the kick panel, but they said I need the one that goes to the overhead console.?. I haven't heard of that. I guess I will keep looking.
There are two harnesses, one for if you have an overhead console, and one for if you do not have it.
Thanks Bill! I did find a link on an old post for a site called motoman. It pretty much describes what you are saying on the spacing. If you know the measurements you used, I would appreciate them. Going off topic, I noticed you did the SS HPX, did it make any difference for you? I am almost 100% sure I want to do it, if nothing else but to help even out the oil pressure. Thanks again, and thanks to everyone that replied!
Dave - The hpx makes it idle better, smoother, I noticed that right off the bat. Its raining like crazy here now - I'll get you the measurements tomorrow and post em up. Edit - Thanks Brandon -Just read your post- Thats the same lights I put on With the chrome around em. I like em a lot. Dave -Just a hint -when you finish and let silicone set up for @an hour or so -Use the hose and double check for leaks b4 you put the headliner back up. Good Luck
Santiagoeford
03-14-2016 10:56 PM
WhatsAChevy?
08-10-2015 07:21 PM
busted 55
03-09-2015 08:03 AM
