My front brake was sticking and now i have brake dust on them bad cant just wipe off can i use brake cleaner to clean them or will it hurt the claer coat
Brake cleaner will hurt the clear coat. First use soap and water. Then maybe try some westley's bleach white on it. If you can get them fairly clean then invest is a mothers powerball with some clear coat polish and go to town. Don't use any kind of aluminum wheel polish because it will haze the clear coat. When you finish use a product called "wheel wax" it is formulated for wheels. It can deal witht eh heat generated from brakes and it actually repels brake dust.
__________________
03' Super Duty, XLT Sport, V10, Auto, Dark Shadow Grey, Banks Powerpack, SVT 18x8 wheels, and Toyo Open Country A/T 285-65-18E
I have had good luck with Maguiars wheel cleaner, just don't leave it on the wheel too long, it says it may damage the wheel, but I have never experienced this and I have used it for anout three years now.
I've used Westley's for years. Gets the tires real black too. I can't use any type of wheel-wet products where I live due to the dust so I just have to keep the wheels as black as possible with no sheen.
__________________
'05 F250 PSD CC Short Bed. 8" Rough Country 4-link Lift all spring rear, 37"x13.50"x17 Toyo M/Ts, Superlift Tru-speed, 4.56 gears, 4" MBRP turbo back with "test" pipe.
before I went to the harsh stuff, I'd try a regular cleaner wax. Most one coat waxes have a polishing agent to make the paint shiny and should lift most all of your brake dust right off and leave your wheels with a nice coating of wax.
Best bet is a degradable, citrus based, wheel cleaner + a pressure washer followed by wiping with a soft towel. Harsher products will harm the clear on the wheels which will result in disappointment.
__________________ BEERING ENTERPRISES, INC. Expert Snow Removal & Ice Management
www.beering.biz '08 F350 Super Snow Fighter
'99 F350 Super Duty
