Ignition control module - Ford Truck Enthusiasts Forums
Old 02-04-2008, 07:44 PM
mudder460's Avatar
mudder460 mudder460 is offline
mudder460 is gaining momentum as a positive member of FTE.
Does anyone know what would make the ignition module go bad? I just put a brand new one on the truck and nothing. Earlier the coil got so hot I could barely hold it. Could the coil do this? I have a 77 150 with I6.
Old 02-04-2008, 08:21 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Is this a stock coil ?
With the key in run ,is there 7-9 volts or 12V ?
Too much voltage will burn out a coil.
The IM are prone for heat related failure if there isn't draft space behind them to cool the circuitry.
Bad out of the box is also a possibility
Old 02-04-2008, 08:58 PM
mudder460's Avatar
It is a stock coil. I will have to check the voltage tomorrow. If there is 12v going to it what should I do? Would that be the voltage regulator? It might have been a bad one out of the box.
Old 02-04-2008, 09:11 PM
No that means there isn't any resistance in the resistance wire or someone has bypassed the R/W.
Old 02-04-2008, 09:14 PM
mudder460's Avatar
I will check the coil tomorrow before I start trying to figure out how to trouble shoot it. I will let you know, thx mil1ion!
Old 02-05-2008, 12:51 AM
jimlj jimlj is offline
jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.jimlj has a good reputation on FTE.
Quote:
I thought I had the same problem, and found it wasn't the IM, but the pick up in the distributor was bad.
Old 02-05-2008, 02:35 AM
roger dowty roger dowty is offline
roger dowty is gaining momentum as a positive member of FTE.roger dowty is gaining momentum as a positive member of FTE.
I wonder if there is an hei for the 6 yet.... i've bought 3 different brands...no problems yet. two wires if you run a tach.....can't get ay easier than that. I've owned numerous 77-84 ford truck/bronco with duraspark and will change it out every time.
Old 02-05-2008, 03:09 PM
mudder460's Avatar
Well I got it running. I think the problem was the coil. I was looking at the 2 I had and one said for "use with electronic ignition" and the other didn't. I think what happened is they guy I bought it from never changed it out when he got rid of the points. That or he just bought the wrong one. Thanks for all the help!
No fire at all allranger 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-05-2014 03:51 PM
1977 ford f250 getting no spark ymirr 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-17-2009 09:34 PM
Ignition module? Lngbeard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-27-2008 02:23 PM
Ignition Module Upgrade why? Dutch123 1978 - 1996 Big Bronco 15 11-27-2007 04:16 PM
Testing duraspark ignition module and coil Steven D Bronco II 1 01-08-2006 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
