1988 F150 shift indicator - Ford Truck Enthusiasts Forums
Old 02-04-2008, 06:16 PM
kubotafan kubotafan is offline
kubotafan is starting off with a positive reputation.
I have a 1988 F150 and the shift indicator is only moving in the d ranges - not P-R-N areas. Is there an adjustment for this or is there something broken? How big a job to fix?
Old 02-06-2008, 06:35 AM
Has anyone else had this problem?
Old 02-06-2008, 07:34 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
There is an adjustment. From memory you remove the two piece cowl from around the steering column (the one just below the instrument cluster). You should then see where the end of the little shift indicator cable attaches to the shift linkage. You will also see where the outer sleive of it is held in place by a sindle screw. If you slacken that screw you can move the outer sleive to adjust the pointer. When you have it set tighten screw.
Old 02-06-2008, 09:36 PM
Old_Paint Old_Paint is offline
Old_Paint is gaining momentum as a positive member of FTE.
Sounds like the clamp is probably broken off, as they tend to do with age. Mine did it on the '86 Bird. I fixed it for a while with zip ties pulled really tight around the pieces of the clamp. I later replaced the cluster (to which the PRNDL cable and clamp is attached, which permanently (until the clamp breaks again) fixed the problem.
Old 02-06-2008, 10:10 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
yeah both you guys are right it's a cable-can't remember how it hooks up to the shifter??-time to grab the book!!!I'll be back!!!!
Old 02-06-2008, 10:16 PM
jr32560's Avatar
the loop of the cable hooks to the column-it should have a plastic adjuster on it-should be behind lower steering column shroud-1986-1990-it sounds like it's out of adjustment or someone has spilled a lot of sodas on the column-sticking!!!
Old 02-06-2008, 11:43 PM
Surge08's Avatar
Surge08 Surge08 is offline
Surge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to beholdSurge08 is a splendid one to behold
Under the cowl by shifter remove the two screws and the cover comes off. The screw for the adjustment is on top of a white peice and is a 7 MM screw. Loosen to adjust. If not replace it. I got mine from LMCTruck.com
stranded overheating BLACKHAWK_1989 1987 - 1996 F150 & Larger F-Series Trucks 7 05-11-2015 01:31 AM
booyah 1988 f150 tranny noise jaltman1984 1987 - 1996 F150 & Larger F-Series Trucks 3 02-28-2014 10:39 PM
Fuel Pressure @ Rail grena 1987 - 1996 F150 & Larger F-Series Trucks 10 03-02-2006 04:39 PM
Shift Indicator cable blueovalboy86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-07-2005 09:18 AM
1988 F150 fuel pump crandall 1987 - 1996 F150 & Larger F-Series Trucks 13 08-03-2002 12:24 PM
Tags
1986, 1988, 1990, cluster, f150, f250, ford, gear, indicator, instrument, low, pointer, prndl, shift, shiftter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
