Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 03-09-2008, 11:24 AM
petey shoes is starting off with a positive reputation.
hi folks, petey shoes here: I drive a 42 MH sno-go year round, 18 years now. have rebuilt most all parts, made radius cornered steel bed, 59ab etc. I pretty much know these trucks! use 20" split rings with 7.50 20 goodyears with good results. I know of a fellow that makes adapters for ANY wheel, 5 to 6, 5 to 10 whatever you need. expensive!!! alcoa is trying to get an order of 10000 sets in order to remake old style aluminum wheels. lets hope so.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 03-09-2008, 11:58 AM
truckdog62563's Avatar
truckdog62563 is gaining momentum as a positive member of FTE.
More info please on the guy making adapters. Guys over on the 1948-1960 page would like to know about him. Name, location, cost, etc? Is he a commercial operation? Thanks. Stu
  #18 (permalink)
Old 03-09-2008, 01:21 PM
hi don, I have info you need at my shop,(drive heavy end dump),will get info to you in a couple days. I do know that he is in tx. and cost is approx 200. per wheel for 5-lug to 10-lug conversion. adapter is a simple project if mechanically inclined. biggest expence is lugs and nuts. you gotta have NUTS!!! plate offsets wheel approximately 1/2 inch. you need to watch tire diameter,width,gear differentials,fender scrub, turn radiaus etc.
  #19 (permalink)
Old 03-10-2008, 12:57 PM
hi STU, sorry about calling you don- senior moment? custom wheel adapters, any size to any size--- info@motorsport-tech.com--- california based do not know price. commercial biz wiil have another address later in week. hope this helps.
  #20 (permalink)
Old 03-10-2008, 01:45 PM
Thanks. I'll email them to see what they can offer. Stu
__________________
Stu
'52 F-3 Marmon-Herrington V-8
'52 F-3 Marmon-Herrington I-6
  #21 (permalink)
Old 03-10-2008, 06:12 PM
merlynr is starting off with a positive reputation.
What are widow maker rims? I have split rims on my 71F350
__________________
97 F250 4X4 7.5
71 F350 dump 360
99 Explr XLS 4.0
05 Mustang GT 5 sp
73 Mustang cpe
71 Mustang cpe
65 Mustang fastback
  #22 (permalink)
Old 03-10-2008, 06:38 PM
bobj49f2's Avatar
bobj49f2 is gaining momentum as a positive member of FTE.bobj49f2 is gaining momentum as a positive member of FTE.
Quote:
I have a page set up on my web site detailing the "Widow Makers"
http://www.fatfenderedtrucks.com/widowmaker.html
Stu and I have been on a campain for quite some time to warn of the dangers of Widow Makers and trying to find alternatives for them. We usually post on the '48-60 board.
__________________
Old trucks, it's a sickness-one I hope they never find a cure for!
Bob Jones--Fat Fender Aficionado--
49 F-2 pickup
48 F-1 panel truck
49 F-1 panel truck (half apart/together)
49 8N tractor
48/51 F-4 flatbed (2 in 1)
My web site
  #23 (permalink)
Old 03-10-2008, 07:21 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
what you have are lock ring wheels
the widow maker was a two piece wheel that is joined about center of the width of the wheel
the two and three piece lockring wheels were fairly safe as long as the componants were in good shape and the person mounting them knew what he was doing
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #24 (permalink)
Old 03-13-2008, 05:26 PM
check out my new address for WHEEL ADAPTERS at, 42 sno-go resto. you will not be disappointed! anyone interested in a 59rt v8 flatty? 49-51 110 hp virgin motor needs rebuild
  #25 (permalink)
Old 03-13-2008, 05:33 PM
bobj49f2's Avatar
What is the address?
__________________
49 F-2 pickup
48 F-1 panel truck
49 8N tractor
My web site
  #26 (permalink)
Old 03-13-2008, 07:34 PM
hey postmaster, click on 47 and older on top of page then click on 42 sno-go resto. info should be at bottom of page
  #27 (permalink)
Old 03-16-2008, 09:20 AM
put a couple shots of daily driver in gallery, check it out!
  #28 (permalink)
Old 03-27-2008, 12:05 PM
phyrphighter is starting off with a positive reputation.
I honestly think, Case1950, that you're where I was at a few years ago. Having to learn about and do the detective work to find these old rims. In a sense you guys that use 20" rims have some advantage because so many more manufacturers used your 20s than used my 17s.
Hey Truckdog - If you need 17's or know of someone that does I had a guy contact me that said he had two - I think he wanted $100 ea. I assume they go on the F-3 ?
I do have 6 of the 22.5's still (one piece) Pic's are available at this link.
http://www.flickr.com/photos/2154125...7604266152131/
  #29 (permalink)
Old 03-28-2008, 12:01 AM
The 17s I'm looking for are Budds with part #59340. That number will be on the back/concave side along the edge of the rim. Generally opposite the valve stem hole. If that's what your friend has, we can talk. If he has other numbers, please come back and let me know what they are. I've mentioned your 22.5s a few times. Somebody needs to buy them. Thanks. Stu
__________________
Stu
  #30 (permalink)
Old 03-28-2008, 02:24 PM
phyrphighter, whats the deal on 22.5"s ? are they structurally and cosmetically sound? I'm anal, looking for GOOD set of four for 42awd. have very good set of 20" lock rings ready for tires but would consider these if they are clean. how wide are rims? do they track straight, (not bent), are lugs 4-3/4 center to center, center hole 6" wide? looked at pictures, need more info. pete
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
