390 Rebuilt
390 Rebuilt
I am in the process of rebuilting my FE390 from a F100 76, I took the block to the machine shop, it was bored 0.030". I have a recepie that I got from this site on parts for a 390 engine, here they are.
KB150 pistons
Crane cam package 343902 (includes the cam 343901 and crane lifters)
Sealed power performance Piston rings
Crane Spring & ret. kit: 270-13309-1
Edelbrock 4bbl part #1406 with electric choke (600 cfm)
Edelbrock Intake Performer RPM
Hedman Hedders HED-89100
I will keep the nonadjustable rocker arm, also, I will get new oil pump, timing chain, new valves.
Let me know what you guys think of this combination, like I said, I got it from the FE forum.
Thnak you for your help.
KB150 pistons
Ran a few different Holley carb a few times on some other engines, and seemed I was either fine tuning or removing the power valve. I could never get the Holley Carburators to Idle the way I wanted them to do.
I was happy with the Edelbrock that didn't have a power valve, which I don't have to worry about blowing and the fuel / air mixture screws adjust fine.
Not sure what Holley carb model, maybe some one will post on a good Holley.
Originally Posted by mlevario99
Also, what is the diference between the KB-150 and the Silvolite 1131,and also the cams.
Thanks
Thanks
baddad457 has mentioned with really good results with Silvolite 1131's, and a Crane 272* Energizer cam.
http://www.cranecams.com/?show=article&id=2
Originally Posted by CaptainIPSC
Where are you all finding the build recipes? I've been searching for weeks and can't seem to find any!!!
Thanks
Thanks
You choosing the best site for FORD Trucks .
Some links on the FE setups https://www.ford-trucks.com/forums/s...25&postcount=3
https://www.ford-trucks.com/forums/6...for-390-a.html
https://www.ford-trucks.com/forums/s...19&postcount=2
https://www.ford-trucks.com/forums/6...hlight=desktop
https://www.ford-trucks.com/forums/s...2&postcount=10
You'll find different FE engine builds that FTE members have used on different threads / posts within this forum. Some FE builds are high dollar with years of searching for specific FE parts and an ever on going search and scraping the pockets to complete their ultimate FE rebuild and other FE builds are off the shelfs with some minor modifications.
I'm runnig the KB 150 with the Crane 343902, and I like the power. If you want more power go with the bigger Crane cam 343941. I've seen mentioned on this forum with good results.
mine is kb150,crane 941, mild home porting. edelbrock rpm intake ,750 holley vacume
3.25 gears .c-6..goes like heck.likes prem gas..
Which Holley carburator do you guys recommend, I am not a mechanic, and this is my first built. Also, what is the diference between the KB-150 and the Silvolite 1131,and also the cams.
CaptainIPSC, I did a search and that's how I found them.
Thanks
Thanks
ZDDP (Zinc dialkyl dithio phosphate ) is the anti wear additive used in most engine oils. Some engine oils have more ZDDP, which is benefical to our older flat tappet designed engines.This ZDDP is utilized as an antiwear film between the flat tappet and cam and other high frictional contact areas in our old engines design.
The EPA (FEDS) are mandating the reduction of Zinc and Phosphorous. These phosphorous and sulfur are elements that plug up catalytic converters which increase exhaust emmission in the atmosphere and enviroment. Eventually the EPA will require zero Phosphorous levels in engine oil and fuels.
The older diesel oils (Rotella T, Chevron Delo 400, etc...) had at levels of more than 1200 ppm of Zinc and 1200 ppm Phosphorus. These deisel oils have detergents to keep our engine clean. The list of engine oils (old and new) with the zinc and phosorus in parts per million. http://www.lnengineering.com/Oilresults.pdf
The new diesel oils have lowered the Zinc (ZN) and Phosphorous (PH) with the new API rating of CJ-4.
The last time I checked the rating of some diesel oils with the API CJ-4 rating had sufficient levels of ZN and PH in their mix.
There is a bulk plant nearby where I can still get the Old Diesel oils. Diesel Engine oils with the API CH-4 and CI-4.
Therefore it is very important to add some engine break-in additive to your freshly rebuilt engine during the 30 minutes of engine running break-in period.
http://www.cranecams.com/pdf/548e.pdf
http://www.compcams.com/Community/Articles/Details.asp?ID=-1578676008
It is very important to run engine oils with high levels Zinc and Phosphate on our older flat tappet designed engines or a flatten cam will be the result.
Some reading material on the subject ZDDP http://www.apmaths.uwo.ca/~mmuser/Papers/TL05.pdf
Raptor119
04-29-2015 03:40 PM
MR-HI-BOY
10-26-2010 07:07 PM
73 ford guy
29
02-12-2010 08:51 PM
73 ford guy
02-13-2008 10:45 AM
stratton
10-21-2003 07:45 AM
