Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 02-04-2008, 03:25 PM
fphilli11 fphilli11 is offline
Garage is empty, add now
fphilli11 is starting off with a positive reputation.
New Member
I just joined this forum and have found it is the best I have seen. I posted a new issue I have with my 2001 Ford 4X4 diesel Excursion with 127,000 miles on it. The front axle or transfercase does not engauge when I switch the 4X4 on either in low or high 4X4. The light comes on the dash but nothing happens. I heard it could be the front axle actuator gone bad. Can anyone confirm this or have a Ford repair standard for this. I do not even know where the actuator is or what it looks like. Thanks in advance....
  #2 (permalink)
Old 02-04-2008, 04:03 PM
bbender85's Avatar
bbender85 bbender85 is offline
2004 Ford F-350
My Garage
bbender85 has a very good reputation on FTE.bbender85 has a very good reputation on FTE.bbender85 has a very good reputation on FTE.
brandon.c.bender
yeah, sounds like something to do with the vaccuum (assuming you have ESOF, not on the floor). i was lucky enough to get the manual shift tcase, so i can't help ya..... but welcome to the site!
__________________
Brandon
'04 F350 CCLB 6.0L, 4" turbo back, EGR delete, Atlas 40 FICM, blue spring, SGII, 2.8" minipack,
285's on 16x10's, DVD/audio goodies
(is this where i list everything else i own to impress everyone?)
  #3 (permalink)
Old 02-04-2008, 07:27 PM
Toyman's Avatar
Toyman Toyman is online now
Toyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to behold
toyman
Welcome to the forums. Try to manually engage the lock out then shift it into either 4hi or lo. If it engages at this time it is most likely the "O" ring seals for the lock outs.
Toyman
__________________
Hi my name is Rich, I am a cornerholic..........
2004 F150 Supercrew Lariat, 3V-5.4L. Daily Driver.....
2004 Jeep LJ Unlimited. 4.0L, auto.....modifications to follow.
  #4 (permalink)
Old 02-05-2008, 09:23 AM
Thanks for the suggestions. I had the vaccum checked and it is ok. I just had my front hubs replaced at the dealership 5 months ago. Great site and quick responses from the group. Thanks again.
  #5 (permalink)
Old 02-05-2008, 02:10 PM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
The shifter is froze up, or the actuator is gone.
pushbutton 4wd is dumb imo. Gimmie a lever!
If that isn't right, then the shift or mode forks are monkied up in the T-case.
__________________
Talyn (AKA: der Schafen Führer)
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, 5 SPD M/T Z/F S5-420, Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM, T-500, 285/75/16 Cooper Discoverer ATR. Steyr C9-A1.
You can get more with a kind word and a 2x4 than you can with just a kind word.
  #6 (permalink)
Old 02-05-2008, 04:12 PM
Thanks
Thanks for the reply. I think it is the actuator. I need to get it up on a hoist so I can see if the plunger is working when I switch to 4X4 hi and low. I am still looking for a repair standard or something that will show me where the actuator is and how to check it out. Thanks again.
  #7 (permalink)
Old 02-05-2008, 07:48 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Post it in here
http://www.ford-trucks.com/forums/forum30/
or here
http://www.ford-trucks.com/forums/forum29/
And you will get all the info you need.
Welcome to FTE!
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 302K
AD's, IC, Rear Disc, OBA, Tuned by Tony Built by me!
Transmission by Racer X!
  #8 (permalink)
Old 02-20-2008, 02:23 PM
Thumbs up 4X4 not working
To all, thanks for the answers and suggestions. I just got my Excursion back and the issue was both front hubs were frozen. The Excusion with lock out hubs do not have actuators, all vacuum system. I found out the hard way you should use the system at least once per month including running in the summer with the hubs locked out. My seals had dried out and hubs froze up. Thanks again.
  #9 (permalink)
Old 02-20-2008, 02:31 PM
bbender85's Avatar
2004 Ford F-350
My Garage
brandon.c.bender
so you put aftermarket ones in i hope?
__________________
Brandon
  #10 (permalink)
Old 02-21-2008, 09:49 AM
Opps
Thanks for the note but the shop I took it to used OEM hubs. I issue was I did not cycle the 4X4 at all last year. The shop told me to cycle them once per month and run with the front axle hubs locked. If I have to do this again which hubs do you recommend?
  #11 (permalink)
Old 02-21-2008, 10:43 AM
bbender85's Avatar
2004 Ford F-350
My Garage
brandon.c.bender
Warn! i went with the premiums when my OE hubs puked this past spring, and they've been great this winter and all last summer at the dunes. they don't have the auto feature (which i didn't have to begin with, having the manual t-case), but you can count on them to work when you need them.
__________________
Brandon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
