I found this over on the 7.3 forum. It is a shackle lift leveling kit that several people on the 7.3 forum is running. I am about to buy it for my 04. Heres the link.
That looks better than good. I was considering leveling my 04 with the front drop hangers but this is much cheaper/easier. rbloodhound, are you going to buy them soon? Maybe you could do a tech write up on how easy it was to do and what problems you had......that way I can do it worry free. Im a great friend arent I?
The thread in the 7.3 forum has several people running these exact shackles without any alignment problems.
I will do a tech write up on it. It should be pretty simple. I have a buddy that does alignments at a tire shop so I will know exactly how it effects the alignment.
looks rigid enough, but it does kind of work against itself with pushing the pinion down, and messing with the caster a little bit. For the little bit its lifting it, it shouldnt be an issue though. just dont want some smart guy to make some 11" long ones thinking its cool......
I ordered them last night. They should be there by the time I get home in a week. I will try to find the tim to do it then. I'll let you all know how it goes.
