Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-03-2008, 10:29 PM
mudslinging79 is starting off with a positive reputation.
rear driveline
blew the rear driveline, the cv joint looking one, and am headed out to the wrecking yard tommorow. what is compatable, like ranger etc?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-03-2008, 10:51 PM
rear drive
also, what kind of socked is used, a 13 wrench will fit, but cant grip the splines, and a socket is too long with a ratchet
  #3 (permalink)
Old 02-03-2008, 11:22 PM
mrshorty is starting off with a positive reputation.
The only "bolt in" driveshafts will come from other BII's. Be aware that there are a few different lengths available, depending on which transmission was installed.
Many people prefer to swap to a more tradiational u-joint style driveshaft (single or double cardan). You might get lucky and find one in a junkyard.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #4 (permalink)
Old 02-03-2008, 11:32 PM
what is the splined typeof bolt called that is holding the flanges together. and what kind of socket is used to take these out?
  #5 (permalink)
Old 02-04-2008, 11:56 AM
5.0B2 is starting off with a positive reputation.
12 point box end -about a 10 or 12 mm --I don't remember the size
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #6 (permalink)
Old 02-04-2008, 12:31 PM
i found a place that sells a30 inch "regular driveline" and my measurements from plate to mounting plate are 31 and 3/8, would a 30 incher work or do i need to go a little shorter to allow for suspension flexing?
  #7 (permalink)
Old 02-04-2008, 04:32 PM
projectnitemare is starting off with a positive reputation.
12 point 12mm will take those bolts out if you haven't already stripped them. BIIs are stil pretty common in the junkyards so you should be able to find something pretty easily. You need to look up to see if there are any driveshafts that are close to 31.5 inches or so. If not then that shaft you have found is probably the one you need, your springs are just really weak and saggy.
Matt
__________________
88 Ranger XLT 4x4, 396W stroker, ZF 5 speed, twin stick NP 205, Perry's Fab n' Fiber fenders & bedsides and hood, 8.8 swap, BII gas tank, lifted a bit, 35in ProComp M/Ts.....4 linked Rockewells and supercharged 557 on the way
  #8 (permalink)
Old 02-04-2008, 04:50 PM
rebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to beholdrebocardo is a splendid one to behold
On one B2 I replaced the 12 pt stuff with reg.metric 9.8 bolts and lock-tite. On another I think I used Aerostar bolts because they had a bigger head that did not strip.
__________________
The Year 2008 Anno Domini -
May it bring a great year of Revelations to you.
  #9 (permalink)
Old 02-05-2008, 10:05 AM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
any drive shaft from a b2 with a A4LD and a 146 are the same length. the 145 tranny is shorter and the C5 is even shorter. is your B2 lifted???? if so you might wanna do this
http://rbvheaven.ipbfree.com/index.php?showtopic=217
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
  #10 (permalink)
Old 02-06-2008, 12:26 AM
well got one from the junkyard till i can get a driveline that replaces the gnkwhateverthehellitis, snapped 2 wrenches, one on each vehicle getting the old ones off. shop has one thats 32 inches, will that be too long? there is no real lift to speak of, maybe 1-1/2 inches,running with explorer springs in the back and 235 tires.
  #11 (permalink)
Old 02-06-2008, 12:35 AM
tbolt 460's Avatar
which one did you get
http://rbvheaven.ipbfree.com/index.php?showtopic=185
__________________
94 Xlporer sport
  #12 (permalink)
Old 02-06-2008, 12:51 AM
got the cv type till my parts dude gets the regular one in stock, am wondering if 32 inches will be too long... the one he ordered is a single i think, with real u joints, stead of the cv crap
  #13 (permalink)
Old 02-06-2008, 12:56 AM
tbolt 460's Avatar
32 should be ok. theres enough slack in the slip joint
__________________
94 Xlporer sport
  #14 (permalink)
Old 02-06-2008, 01:08 AM
cool, ill put in the order on payday, just getting around on this junkyard replacement for now. lowest price i found is 219+ core, is that a deal?
  #15 (permalink)
Old 02-06-2008, 01:13 AM
tbolt 460's Avatar
what year is your rig??
__________________
94 Xlporer sport
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
