Similar to Crane Fireball?? - Ford Truck Enthusiasts Forums
Old 02-03-2008, 10:26 PM
Vulcan315 Vulcan315 is offline
Vulcan315 is starting off with a positive reputation.
Howdy folks,
I'm new to the forum. Had a '67 Fairlane w/428 back about 20 years ago, and really loved the FE engine.
I'm just starting a journey on a 390 powered '74 F-100 I got from my dad. He bought the truck new, and went through about 170k miles on it. Sometime about 10k miles back he rebuilt the driveline, installed a locker, and stuck it in a barn around 2000.
When he built the engine, he installed a Rhoads VVT cam & lifters. I had a Crane fireball in my Fairlane and loved the sound of it (silly, but I really loved the sound). I was thinking about swapping one of these into this engine, but when I called Crane, I found it was no longer available. I no longer have the specs on the Fireball... I wonder if anyone out there knows the Cam I'm talking about, and if there is anything similar to it available these days.
Thanks for any feedback!
Dave in NC
Old 02-03-2008, 10:32 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Shiftoholic
Freightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to beholdFreightrain is a splendid one to behold
I had one of those but it was a small block version back in late 80's. I did not run it long, as my combination back then didn't like it. If I recall it was advertised at 292 duration?
Welcome to FTE!
Old 02-03-2008, 10:40 PM
Redmanbob's Avatar
Redmanbob Redmanbob is offline
Redmanbob is gaining momentum as a positive member of FTE.Redmanbob is gaining momentum as a positive member of FTE.
I seen one actually 2 on ebay in the last week.. check on it..
Old 02-03-2008, 11:30 PM
Quote:
Thanks, I'll check on that. Basically what I'm looking for is a cam that will work with my stock valve springs & flat top pistons, and have a nice lumpy idle. Dad built this engine from a '69 390 block & factory 4bl manifold, but said he used a set of cleaned up 360 heads (and installed adjustable rockers) because of the smaller chamber. He had a local shop to bore the block .030, installed flat tops, and has a set of tube headers on it.
Dave
Old 02-04-2008, 12:42 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
I knew I had the specs for the Fireball somewhere. I ran one in the 428 I built to run in my race car in 1970. Well at least part of the specs. The car, a 1969 Torino Cobra notch back, weighed 3200 pounds and ran 12.96 in the quarter on it's first pass. Ran in the 12.50s at 120 mph after suspension tuning and a tire change.
296 duration
.509" lift with 1.73 rockers
.517" lift with 1.76 adjustable rockers
Thats all that is written in my memory book.
Old 02-04-2008, 10:30 AM
R-WEST R-WEST is offline
R-WEST is starting off with a positive reputation.
Had one of those in a 390 we put in my bro's F150 back in the '70's. Definitely a neat idle, and a good performer. If you can't find one on the 'bay, maybe the top end of the CompCams High Energy or the lower end of the Magnum series would work. The specs appear similar to what Bear recalls (wow, that's a pretty good memory, Bear!!), although the Fireball MAY have had a 108 lobe separation, which helped give it that lopey idle - the HE and Magnums are 110. Be sure to check valve/piston clearance in any event.
Crane still lists a replacement for the F294 solid lifter version - a cousin had one of the originals in a 428; nice clattery/lopey idle. Ahhh, those were the days.....
Old 02-04-2008, 11:03 AM
Bear 45/70's Avatar
I wish my memory was that good. But I have a loose leaf notebook with all kinds of things written in it from my car racing days. A lot of useful and totally useless info in it. But I wrote it down and still have it. Have one from my boat racing days also but that's all 2 stroke stuff and tunnel boat info.
Old 02-04-2008, 11:51 AM
Shiftoholic
My guess was pretty close too! And I didnt' even have a notebook LOL!
Old 02-04-2008, 01:09 PM
Bear 45/70's Avatar
Quote:
IIRC, I choose that came because of the additional lift over the CJ cam.
Old 02-04-2008, 02:15 PM
Okay, so all these memories got me to thinking that a lot of those cams were also available through various aftermarket sources years ago. Some said they were even made by those guys and marketed through Crane and others (anyone else remember Manley's "Thunderstick" series?). Speed-Pro, TRW and others certainly showed grinds with similar specs, at one time, too.
Anyway, I dug around at the PAW site and found one that looks like it's close to the original's specs - 223/223 @ 0.050" & 0.513" lift. Look at http://www.pawinc.com/Ad_All-2.html#Ad2Top page 2, part #10355. Might be worth a call.
We've used more than a few of their 204/214 - .484/.510 grinds in 351's & 400's, and the 224/224 - .465 which is the hydraulic version of the small-block 289/271 HP grind, over the years, with no problems.
Old 02-04-2008, 07:23 PM
FFR428's Avatar
FFR428 FFR428 is offline
Needsmorecoffee.
FFR428 has a good reputation on FTE.FFR428 has a good reputation on FTE.
I have a old solid FE Crane Fireball cam. Specs it came with were 292 advertised duration, 227/227 @ .050, .523/.523 lift. 114.5* lobe sep. Came with a 406 I bought years ago with 3 flat lobes!!! But the cam card was included!!! LOL. IIRC it was the only FE grind in the Fireball series. I think I have a old PAW catalog with those in it somewhere. Cam is currently a door stop.
Old 02-04-2008, 08:37 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
The old Holman-Moody HM310 worked with the GT/CJ springs too and had a wicked idle. It's specs were 310/310 with a .515/.515 lift. This is the cam I ran in my 427 back in the 80's.
Old 02-04-2008, 08:38 PM
Redmanbob's Avatar
If no one minds... when I dropped off the 390 parts at R&D John mentioned he has used a cam with about an additional 10 added to the exh duration as the FE heads have such a small exhaust vale and a large intake valve. He mentioned that you want about 85% of the intake for the exhaust and the extra duration helped with this. Opinions/Arguments/Couldgiveadamns????
Old 02-04-2008, 08:41 PM
If there is, you'll only see it on a dyno. The FE's just aren't as bad on the exhaust side as the other Fords were. Except for the crappy manifolds they were hobbled with.
Old 03-03-2008, 09:30 PM
Redmanbob's Avatar
was gonna email you but then realoized thats turned off. Then noticed only two posts on the board... well here goes nothing!!!http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
maybe someone can make use of it.....
How much should I worry about rust? ninerhb 1987 - 1996 F150 & Larger F-Series Trucks 10 02-05-2012 08:14 PM
Driving with bad EGR Cooler FireBaller74 6.0L Power Stroke Diesel 4 12-09-2010 11:43 AM
Crane seems back in business Argess FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 7 07-11-2010 05:29 AM
Crane XR-I Electronic Ignition Upgrade F250camper 1967 - 1972 F-100 & Larger F-Series Trucks 15 10-24-2003 06:50 PM
Comp cam vs. Crane freejay FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 15 08-29-2003 10:57 PM
Tags
1969, 296, cam, check, cobra, crane, fairlane, fireball, ford, heads, make, notch, similar, specs, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
