Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-03-2008, 04:46 PM
Broncboy86 is starting off with a positive reputation.
Efi 302 runs lousy
well I got my efi conversion.
87 HO out of a mustang gt 5 speed.
Problem:
as the engine warms up it starts to back fire and cut out when I accelerate. Ive replaced the fuel pressure regulator and Ive ran the codes. the only code I get is egr poodle poop which I just took off and cleaned up. it was almost clogged shut. so IDK somebody please help.
Oh I set the base timing at 10 Deg with the spout disconnected and hooked the spout back up and the timing went up to 25 deg advanced. is that Normal???? that seems way too advanced.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-03-2008, 08:16 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
What computer and engine harness are you running?
What fuel pump are you using?
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's, FRPP Mass Air, TweecerRT 282HP
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #3 (permalink)
Old 02-03-2008, 11:04 PM
RCrawler's Avatar
RCrawler is gaining momentum as a positive member of FTE.
Did cleaning the EGR clear the code? Do you have the EGR connected properly? Does it run ok when cold?
Have you checked fuel pressure? Should be 35-45 psi.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
  #4 (permalink)
Old 02-04-2008, 04:25 PM
I am working on getting a fuel pressure tester, kind of low on money right now. I havent checked the codes again yet. everything is hooked up as I think it should be. and when its cold it stumbles at idle and sometimes dies. but as it warms up it idles fine.
It is an 87 HO computer from a Mustang gt five speed. Speed density, I bought the wiring harness, computer, etc etc. all from the same car.
  #5 (permalink)
Old 02-04-2008, 06:46 PM
Conanski's Avatar
OK.. now we're getting the picture. What are you using for a fuel pump? You have the plugs wired 13726548 right?
__________________
Paul O
  #6 (permalink)
Old 02-04-2008, 07:35 PM
RCrawler's Avatar
Was this a complete engine, or were you adding EFI to your current 302? Like Conanski said, double check your ignition wiring and verify that your distributor is not 180 out (make sure you were on #1 compression when you set the dizzy).
Any off idle vacuum leaks, unused ports not plugged? You have a vacuum line to the MAP sensor?
Buy or borrow a fuel pressure tester. Will really help to isolate your problem.
Jason
__________________
  #7 (permalink)
Old 02-05-2008, 01:28 AM
yeah Im borrowing a tester tomorrow so Ill check that. im almost positive that Im at #1 tdc. ill have to check that tomorrow. and I have triple checked all of my vacuum lines. and yes map is hooked up. Ill post asap the pressure im at.
Thanks guys.
  #8 (permalink)
Old 02-06-2008, 06:55 PM
fuel pressure is fine.
  #9 (permalink)
Old 02-07-2008, 01:01 AM
RCrawler's Avatar
What firing order are you using? Was this a complete engine swap or just adding EFI to your existing?
Jason
__________________
  #10 (permalink)
Old 02-07-2008, 10:59 PM
Quote:
Jason
I put in a new cam with the HO firing order. I am adding this to my existing engine. I have 2000 miles on the engine. and is all checked out ok.
  #11 (permalink)
Old 02-08-2008, 11:27 AM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
what are the cam specs??? speed density must have a cam with 114* or more lobe seperation. if its below that it wont run properly. Also what size injectors are you using?
I have a mass air overlay harness and mass air meter if you wanna go that route let me know. I can use it on my bronco due to the E4od.
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
  #12 (permalink)
Old 02-08-2008, 03:55 PM
i have a 208/216 with .530 lift. i wanna say 112 lobe seperation. but I called Crane and its rated for this motor. Im running 19lb injectors. its the HO setup. I might be interested in maf. how much would you want for it? And do you have everything to plug n play. or will I need to buy anything else????
  #13 (permalink)
Old 02-08-2008, 05:15 PM
i know crane said that but i am willing to bet that cam is part if not all the problem. you will have a pm regarding the harness
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #14 (permalink)
Old 03-03-2008, 11:39 AM
if your still interested i have lowered the price on that harness
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #15 (permalink)
Old 03-03-2008, 11:58 AM
Conanski's Avatar
I'll ask again.. what fuel pump are you using? If this was a carb'd vehicle with an electric pump you need a different pump, because while it may build enough pressure at idle it won't supply the volume necessary to maintain pressure under load. You shoud be getting 32psi at idle and it should jump to 40-45psi when the throttle is opened.
__________________
Paul O
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
