Any 289 Mustang engine gurus out there?
  #31
Old 02-04-2008, 05:03 PM
cool 48's Avatar
cool 48
cool 48 is offline
Problem solved
Well guys, I figured it out. The vacuum line that had come loose and fallen off probably did not fall off at all. It probably blew off during one of the very bad hesitations the truck had on my way home the other day. Well, yesterday I completely rebuilt the carb,and no change. Ok, now I can rule that out. So, I went ot the next thing. That was the points. I ordered some points from my local napa dude,and picked them up this afternoon. When I got to the shop ,I noticed they were the wrong ones. So, I removed both sets and carefully filed them smooth again. Both had some pitting in them. I put them in the truck set the gap, and she fired right up. Not even a stumble. It idled like the day I bought it. Well, a little better. So ,I decided to change out the plugs too,along with rotor ,cap and condensor. This is the stupid part. My needle nose pliers were laying in that little channel on the front of my truck, when I noticed they fell down between the radiator and the grill. I picked them up and went on working. A moment later ,I felt a wet sensation on my leg. My radiator was peeing all over me. My needle nose pliers had punctured my radiator. Can you believe that? I just laughed .But , whoever owned the truck before me had put the tranny cooler bewtween the radiator and the cross member on the front. He used ty raps to hold it in. And used the radiator to pinch the tranny cooler to the crossmember. That gave me a chance to change that up. I soldered the radiator and repositioned the tranny cooler. Now, everything in my world is right. I took off early today to work on it. One of those nagging things , .. you know what I mean. The real funny thing ,is the other day my wife just blurted out ...did you check the points? She laughed ,and said ... heck I don't even know what they do... I just heard my dad say it all the time. Turned out , that was good advice. Thanks for all of your help guys. Maybe I can help you some time.
  #32
Old 02-04-2008, 05:08 PM
eman92082's Avatar
eman92082
eman92082 is offline
Good For You !
  #33
Old 02-04-2008, 05:16 PM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
Glad you got it going. Now the 10 million $$$$ question, Did you learn anything? I wouldn't ask if I hadn't done things very similar. Burned points will act very much like fuel problems. It would be a good time to start looking for an electronic ignition system, they are almost trouble free.
  #34
Old 02-04-2008, 05:17 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,575 Likes on 1,286 Posts
Do check your timing chain though. With the distributor cap off, rotate the motor by hand until it moves. Reverse the rotation and see how many degrees of crankshaft rotation it takes to take the slop out of the chain. More than a few degrees and it's replacement time.
I used to notice my idle fluctuation between kind of crappy then smooth out. The theory was the slack in the chain evening out and cam/ignition timing moving around.
  #35
Old 02-04-2008, 05:26 PM
53fatfndr's Avatar
53fatfndr
53fatfndr is offline
Glad you got it figured out
  #36
Old 02-04-2008, 05:41 PM
cool 48's Avatar
cool 48
cool 48 is offline
Well, had the truck just crapped out ,and I had to trouble shoot it, I would have done things different. But when I got home and found that vacuum plug laying on the manifold,I just figured that's all it was. Because I knew that truck would n't even run with out that plug connected. Thanks again fatfndr
  #37
Old 02-04-2008, 05:47 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
You mentioned your running dual points. No offense but they are the worse!!!! I bet if you checked the points they are most likely fried!. I had nothing but trouble with my Mallory dual point so I tossed the points and put in a Pertronix ignition. No more problems. Come to think of it, my dual points did the same as your engine is doing. Edelbrocks run well even if they are dirty. You may want to check the screen at the carb inlet (where your fuel line connects) sometimes that get plugged with crude which cause the carburator to starve for fuel.
OOPS! I just read the other posts and you figured it out. Anyways, get rid of the points. You'll be much happier.
  #38
Old 02-04-2008, 06:01 PM
cmoritz's Avatar
cmoritz
cmoritz is offline
Victory!..I second Mechmagcn , Toss that point system ,go for the reliability of solidstate...just another upgrade to make your life easier! Good Luck!
  #39
Old 02-05-2008, 09:38 AM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
YYaaaahhhhh! another happy ending. You went from pulling your hair out to point guru in record time. But, you know it's just a matter of time until those points do it to you again.
As for the slipping tool problem, I bought several of the rubber fender covers. I have the traditional leather covers also, but the rubber mats are better at keeping the tools from sliding. They sell them at car swaps for $15 and they are worth it. Good luck, Jag
72##ford
10-09-2014 03:31 PM
compman
12-22-2013 09:23 PM
1975FordF250
09-20-2013 07:54 PM
findingidaho
09-08-2013 09:54 PM
Crazy66Dog
07-25-2013 04:38 AM
Quick Reply: Any 289 Mustang engine gurus out there?
