definitive test of penetrating oils
#62
I had another go at the acetone/ATF mixture with the other exhaust manifold on the swap motor. This time I drenched ever bolt and heat shield nut a few times and let it set for 2 hours. I only had 1 bolt break off on me which is a big improvement over the other side where I had 7 break!
What got my attention was when I removed a crusty bolt, I could smell acetone on the deep threads, so maybe it does get deep down in there.
#63
Results: Complete and total sucess the minute i put the socket on each bolt head the broke loose. Made that the easiest water pump replacement I have done. Thanks for the advice on that one. I will never go wrong with this again.
On a side note applied same 50/50 to my torsion bar bolts (04 Heritage) which had been siezed from tons of road salt. Cranked on them and set exactly where I wanted, easy as pie.
#64
I assume that the ATF/Acetone mix were talking about here is auto tranny fluid and another chemical mixed together, correct, if not please clarify this as I do use quite a bit of product and have yet to find that one really good solution for extream rusted screws/bolts/nuts situation...i used panther p*$$ and eh didn't work, infact I stripped out a screw that was rusted on to a hood of a 96 truck trying to remove a bug guard....some help that was...lol!!!!
jim henderson
General Automotive Discussion
46
07-02-2017 12:52 PM
NAMDROF
13
04-05-2011 11:02 PM
76f350spercamprspeal
15
02-18-2008 05:14 AM
hd4ever
06-04-2007 08:12 AM
acetone, acetoneatf, atf, automatic, fluid, goverment, oil, oils, penatrating, penetrating, result, test, testing, transmission, types
