429 truck engines
Old 07-15-2001, 08:40 AM
Nathan's Avatar
Nathan
Nathan is offline
429 truck engines
Does anyone know if the 429 ci engines installed in the big trucks through the 80s are the same basic engine as the 385 family? By this I mean can you directly replace one with a 460?
Thanks
Nathan
Old 07-15-2001, 11:30 PM
mike460's Avatar
mike460
mike460 is offline
429 truck engines
if its a 429 then its part of the 385 series....same exact block as a 460. to make a 460, just find a 460 crank, pistons, and rods. hope this helps.
mike
Old 07-17-2001, 08:40 PM
proud owner's Avatar
proud owner
proud owner is offline
429 truck engines
Old 07-17-2001, 08:57 PM
proud owner
429 truck engines
YES, you can directly replace the engines.
429/460 are the same engines except for the Crankshaft and pistons. To turn a 429 into a 460, get 460 crank, rods and pistons... to turn a 460 into a 429, get the 429 crank, rods and pistons. The blocks, and everything else in/on the blocks are Identical..... have fun
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old 07-17-2001, 09:29 PM
bb79ranch's Avatar
bb79ranch
bb79ranch is offline
429 truck engines
From what I was told a few years back, the 429 heavy truck engine IS essentially the same as the 429/460 engine family. One of the things that makes the heavy truck engine different froma pass. car/truck 429/460 is that it uses a FORGED STEEL CRANK, but to use it in a "regular" 429/460 you have to mill down the snout where the harmonic balancer resides in order to use the passenger car/truck balancer. There could be other differences but this is the only one that I recollect. I hope this helps.
Todd
BB79RANCH
Old 07-18-2001, 12:51 AM
85351ho's Avatar
85351ho
85351ho is offline
429 truck engines
just to add something small, the rods on the 429 and 460 are the same, the better ones are scj and truck motor rods
1985 F-150/351Ho/c6/4wd
1979 F-150extcab4x4/460/c6/6inchlift w/60rear44frnt
on a quiet night your can hear a chevy (lol,you can watch a dodge) rusting away
Old 07-18-2001, 06:36 AM
Nathan's Avatar
Nathan
Nathan is offline
429 truck engines
Thanks guys. I dont have the truck (it has a scissor/dump bed) but may be able to get it cheap. Just wanted to know if it would be much trouble to get a motor in it.
Nathan
Nathan511
01-28-2017 12:36 PM
Nathan J. Hickson
01-24-2017 11:19 AM
nathan_2017
2017+ Super Duty
12-11-2016 11:35 PM
Nathan2115
12-11-2016 12:44 AM
berry1234
Large Truck
09-24-2013 10:13 AM
Quick Reply: 429 truck engines
