Oil Feed Line seal
Oil Feed Line seal
I'm rebuilding my 1955, 223, 6 cylinder motor. Does anyone know where I might get the oil feed line SEAL that goes on the end of the tube/pipe that pushes into the engine BLOCK? These are the two tubes which feed oil to the rocker arm assembly and valve train. I have one that is very worn out and I need to replace both ends/seals, they are very similar to a ferrule or bushing but have a Band style "o" ring. Thank you
Received 1,344 Likes
on
