there are separate servos or something that control the 4 directions. I put one back together and there is no reseting them. It is esentially 4 separate threaded motors. motor unscrews and mirror adjusts out, screws in it adjusts in. Motor stays put and threaded insert moves in/out.
I would look at the switch area. If it moves as it does, it must be the control portion.
Good luck
__________________
03 V10 Excursion Limited 2WD
3.73LS, 6" Fabtech Lift, 35" PC Xtreme ATs
Line X'd Brush Guard and running boards
FM Super 40 w/dual 3" pipes, RAS
11.5+ mpg in town, 13.5+ on the highway
Still miss my 96 Bronco
