Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-02-2008, 07:19 PM
CKBLOOD05 is starting off with a positive reputation.
? about xcal-2 programmer on my tune?
i have a 2000 xplorer sport and i have the xcal-2 programmed with a tune.but in the modify parameters where you can choose your axle/gear, mine is on stock.but my truck has the 3.73 gears in the rear end.should i leave my tune on stock or put it on the 3.73 on the xcal-2? since thats what the truck has.but will it even make a difference? if it don't matter if its on stock or on the 3.73,then i'll probably just leave it on stock.but if putting it on the 3.73 will be better then i will change it. any help or suggestions will greatly be appreciated.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-03-2008, 09:50 AM
Johnny Langton's Avatar
Johnny Langton is gaining momentum as a positive member of FTE.
Quote:
The PCM has a few lines of code that are vehicle specific assigned when the PCM is programmed for that specific vehicle that it'll beinstalled it. It's called the VID(Vehicle ID) block. Information there are things like Axle ratio,PATS information,etc.This axle info can be ovedrriddin within the software by changing a couple of system switches and the axle ratio scalar.
If you're using the stock axle,then leave the file as "stock",and the software won't alter the settings,and everything will work fine.
JL
__________________
1997 Thunderbird LX 4.6L/4R70W
12.16@111.78
1998 F150 Supercab 4.6L/4R70W-Gone,sold to Dad.
2005 F250 Crewcab
3V V10/Torqshift 4.10LS
2001 Navigator
WANTED: OEM cat-back Exhaust from 2005-2007 5.4L or 6.8L Superduty
  #3 (permalink)
Old 02-03-2008, 04:28 PM
ok that makes sense.i was told to just leave it stock by a couple other people to.thats where it has been since i got the tune.thank you very much for explaining that info for me!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
