taurus sho motor in 96 ranger - Ford Truck Enthusiasts Forums
Old 02-02-2008, 01:15 PM
lrd56 lrd56 is offline
lrd56 is starting off with a positive reputation.
Smile taurus sho motor in 96 ranger
im wondering about putting in a taurus sho motor with a t56 trans in my 96 ranger .i know i need a aerostar manual bell housing.wiring & computer for the sho motor .i want more hp &torque than the 140hp 4.0 v6.140hp wow .my rear gears are 3.45 with 30 inch tires.new ratio is 2.99
will it make much diffierence from the 2.3 .with 98 hp wow.
i want to keep a manaul trans.no slip& slide trans.
Old 02-03-2008, 01:05 PM
Matts72's Avatar
Matts72 Matts72 is offline
Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.Matts72 has a good reputation on FTE.
You would probably be better off by re-gearing the truck, or skipping the SHO and putting in a 302. I would re-gear first and see if you like it a lot more. My '08 Ranger has 4.10 gears on the stock tires, and I get around without a problem, granted I also know its not a V8 F150 too...
Old 02-03-2008, 02:29 PM
427SOHC's Avatar
427SOHC 427SOHC is offline
427SOHC is starting off with a positive reputation.
Is the t56 tranny a rear wheel drive tranny? I used to have an Taurus SHO and was pleased with the performance.
I have installed a Lincoln Mark 8 4.6 in my 79 F100, I still have plenty of work to do. Pictures are in my gallery.
I met a guy from Michigan that installed a GM Northstar engine in his S10 with a 700r4 tranny behind it with a slight mod to the bell housing to accomodate the starter being on the top side of the engine.
Anything is possible if you want to do some work.
Old 02-03-2008, 11:55 PM
RangerPilot's Avatar
RangerPilot RangerPilot is offline
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
The SHO is also a car engine...and not a real great upgrade. I think you'd be much happier with a V8 of some sort in the truck, a nice 351W wouldn't be too hard and with a manual it can go pretty good.
Old 02-04-2008, 12:58 AM
Matts72's Avatar
I've done the 351W/Ranger, and I wouldn't recommend it for a street driven ranger. It has too much power for the little Ranger chassis. Eventually mine was pretty ***** to the wall, 650 horsepower/590 Ft/Lbs at the rear wheels, but it started pretty close to stock to get the block seasoned.
Old 02-04-2008, 01:03 AM
I've gone with the 302/T-5 combo in a Ranger and wasn't too satisfied. It was definitly better than the 4.0L/M5OD, but nothing too special or outstanding, even with mild upgrades. That's the only reason I suggested the Windsor to him.
Old 02-04-2008, 01:07 AM
Matts72's Avatar
I've done the 302/C4 in an 83 and I was very happy with it. It was a 2wd and it still needed a lot of frame stiffening for that motor, and it was right about 230HP/250TQ.
Old 02-04-2008, 08:21 PM
427SOHC's Avatar
My brother in law and I installed a 350 small block and turbo 400 tranny in a 83 Toyota 4x4. What a monster that was!
Old 02-04-2008, 09:13 PM
Matts72's Avatar
Thats about the only way a Toyota is worth anything... a nickel is something...
Old 03-23-2008, 12:22 PM
captaingofast's Avatar
captaingofast captaingofast is offline
captaingofast is starting off with a positive reputation.
I have an 84 Mustang 5.0 in my 90 Ranger. I'm running a mildly lumpy Crane Fireball cam, Edelbrock carb/intake, headers and stock heads that have been massaged a bit. It dyno'd at a tad over 240 hp at the rear wheels. That's enough gofast for me. Your results may vary.
Old 03-25-2008, 06:59 AM
wendell borror wendell borror is offline
wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.wendell borror has a great reputation on FTE.
There's alot more stuff out there for installing a V-8 into the ranger than the yamuha 3.0. James Duff sells conversion kits just for the ranger V-8 swap.
Old 03-25-2008, 12:38 PM
oops wrong engine
my ranger has a 2,.3/5 speed.
SHO reject notice RojoStar Aerostar 29 01-29-2017 03:25 PM
New Guy here from Fort Wayne SHOBoat Indiana Chapter 9 03-02-2015 08:18 AM
First heavy haul breedo99 1994.5 - 1997 7.3L Power Stroke Diesel 8 05-22-2014 12:56 PM
Sho v8 lunargreen Ranger & B-Series 8 10-17-2009 11:52 PM
Taurus SHO F250kid General Automotive Discussion 17 10-22-2005 02:39 AM
Tags
c4, conversion, engine, ford, motor, powered, ranger, sho, shoswaps, swap, swaps, taurus, trans, v8, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
