You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Series Wheel Finish: Black Size: 17'' x 8'' Bolt Circle: 5 x 5-1/2'' Rear Spacing: 4-1/2''
In your opinion which wheels will fit better and look good? If, neither of these sizes then what would you recommend? I want to upgrade from the current stock 15 inch rims on my 1979 Ford F100 2wheel drive. What Rear Spacing do I need as well?fficeffice" />>>
Series Wheel Finish: Black Size: 16'' x 7'' Bolt Circle: 5 x 5-1/2' Rear Spacing: 4''
Take off one of your wheels and lay a ruler or something across the backside of the rim. Measure the distance from the lower edge of the ruler to the mounting flange of the rim. This is the backspacing.Too little, and the tires will stick out past the fender. 4 or 4 1/2 should be OK. I have 8" wheels with 4" and they fit just fine.
leshall89 you need more backspace or they will stick out. I have 5" backspace and I would like to see another inch more backspace so they will tuck in there. Then you have to worry about the insde of the tire rubbing.
Don't know if you have a Flareside or not, but I have 15x10's with 6" of backspace on mine, Mickey Thompson N50-15 tires (14'' wide) and they're inside the fenders . . . . barely! 15x8's with 4" of backspace on front, Mickey Thompson H50-15's (12" wide). Again, barely. I've got 2" between the tire and the rear spring.
rick that looks real nice! Is that stock height? Are those custom rims or were you able to buy them off the rack with that backspacing?
My 74 is a fleetside.
Les
The front wheels are "off the shelf" American AR-767 wheels. The rear 15x10's I ordered from Stockton Wheels in California. They just happen to look "exactly" like the Americans. They are Stockton's "Explorer" series. They were $105 ea. plus shipping back in 2003. Who knows what they are now! Trim rings were from Pep Boys. I dropped the rear about 4" or so and cut a coil and a half out of the front springs (I think!). Anyway, I like it!
If you want a 10" wide wheel you need between 5.5 and 6" of backspacing especially if you lower it. I have 15x10s with a 325/50 drag radial and they just fit with 5.75" backspacing. I also had to hammer the wheel well in to get them to fit but any less backspacing and they would rub on the outside even with the lip rolled.
droppedf100, are your rear wheels custom built or off the shelf?
They are off the shelf but were widened 2" on the inside. They are steel Cragar street lights not aluminum. Im in the process if switching the bolt pattern to 5x4.5 so I can put Weld draglites on it to save a punch of weight.
doesn't appear there's a 15x10 with 5 on 5.5 lug pattern aluminum wheel available with 5.5 to 6 inches of backspace off the shelf. can anyone refute that?
