Raw Fuel Smell when Idleing
I have a 2005 Expedition with the 5.4 Triton , just recently I am getting a huge drop in fuel economy and also noticed a Raw fuel smell when I am idleing , checked for any pooling or wet spots of fuel but none found. Anyone else experiencing the same problems???? Don't know if it is coinsidence or not but I just recieved a letter from Ford about Faulty Fuel Injectors ??? . No check engine light or rough idleing??? HELP!!!
No check engine light has come on ?? , the engine seems to run and idle fine but can't figure out why the drop in fuel economy and the smell . I was hoping to do some investigating on this before sending it in to the dealership . Not that it isn't worth it but $95.00 a Hr to tell me nothings wrong ?. I would rather do some reserch with people who have had simalar problems and do my own troubleshooting for now!!!.
Raw Fuel Smell
Yes , I smell raw fuel coming thru the vents , especially if the vehicle is idleing , warming up in the morning, or sitting for 3-5 min ideling . once the vehicle is travelling it seems to stop . Someone had mentioned that the charcoal canister gets saturated and can cause the purge valve to stay open ??? . no way to check this unless I take it in to someone with the proper diagnostic tools. Any other suggestions before taking it in?.
I had the schrader valve (fuel test port) on the fuel rail start leaking on mine. Smelled, no puddles, but was leaking like a fountain. This happened to be after a plug ejected. But you might pull the cap and check. Any other connection in the fuel system could give similar results.
A bad injector should be noticable at the tailpipe. Leaking fuel will only be up front. Either way, taking it in is sound advise.
B.Puckett
1999 to 2016 Super Duty
07-24-2015 09:12 PM
matowns21
12-26-2011 08:15 PM
