Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V8 (4.6L, 5.4L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-01-2008, 11:41 PM
allisdeere is starting off with a positive reputation.
New and need help with 03 F250 5.4 ALT?
Hi all, My name is Richard Davis(43) I am retired from the Navy and live in Indiana. I work for Praxair as a Field Service TECH. I grew up in Rushville Indiana in rural Rush county, married with 2 girls 4&6. The bad part is I am also stage 4 lung cancer. Was given 6 months to live almost 2 year ago. Told those Doctors to kiss mine in 15 years LOL.
Have a 2003 F250 with 5.4 V8. Replaced the altinator cause it was putting out over 16 volts and lost the gages and the radio intermittently. Replaced with new altinator in the beginng I was only getting 11.5 volts, now I am getting anywheres between 11.5 to 15.7 volts and the same thing with the gages and radio. When the voltage was steady at 11.5 volts, my gages and radio worked as they should have, but the battery light on the idiot panel was light. Did I get a defective altinator? Is there a relay that turns the regulator on/off that may be defective? Have I fried some computer? I am going to replace the altinator again tomorrow and see what happens. Any advice is greatly appreciable.
Thanks Rich
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-02-2008, 08:26 AM
LxMan1's Avatar
LxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to beholdLxMan1 is a splendid one to behold
Sounds like a bad alternator. I would also check the cables good on both ends, for corrosion and a tight fit. Especially the grounds. There is also a large ALT. fuse in the fuse panel under the hood. Make sure is is ok.
Oh and by the way, welcome to the forum Rich. Hopefully you will be around here for a long time to come!!
__________________
Jimmy- FTE Moderator
Support FTE....Online Store
88 5.0 LX Mustang
63 F100 351W/C6
  #3 (permalink)
Old 02-02-2008, 07:09 PM
chrisf250-460 is starting off with a positive reputation.
welcome to FTE. it sounds like a bad alternator.i had to put two on mine before i got a good one.good luck
__________________
  • 1998 f150 4x4 5.4 auto
  • 1986 f250 4x4 460 auto
  • 1969 mustang machI 351c auto
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
