02 F250 Stuck in 4x4
02-01-2008, 09:37 PM
on
I have a 02 7.3 4x4 and it's stuck in 4x4 low. It was stuck in 4x4 hi until I shifted it into low. It has been very cold and icy here but now it's above freezing and I'm still stuck. Any Ideas?
oops, It's semi auto hubs and flip a switch 4x4.
02-01-2008, 11:27 PM
I don't know what you mean by semi auto. Put it in 2wd, backup a few feet, put it in nutral and let it have enough time to let in shift. I don't have enough information to help yet. Do you have manual hubs with auto switch?
02-01-2008, 11:41 PM
on
They are auto hubs but I can lock them manually unlike a 350. I have ESOF switch on the dash. It went into 4hi and then would not go out. I backed up and did everything. I put it in low to see if the actuator would move and it went into low but now it will not go back to 4hi or 2wd. (now I'm screwed) I tested the switch on the dash and I get different resistence settings for each posistion. Vacumn lines seem ok and all 4wheels are turning.
02-02-2008, 02:18 AM
on
Change the two relays under the hood.They might have moisture in them.They should be on the drivers side fender/firewall area. That's what was wrong with mine.
DuallyMike
1999 to 2016 Super Duty
08-25-2011 08:27 AM
shaneswisher
2009 - 2014 F150
02-03-2010 09:40 AM
greenterror
03-19-2009 05:42 PM
jayyslow
05-21-2007 06:31 PM
Daman858
02-17-2006 04:28 AM
