429 compression results
Old 08-12-2001, 04:15 PM
rwjr's Avatar
rwjr
rwjr is offline
i am burning a quart every hundred miles in my 429, so i did a vacuum and compression check....the vac reads at 19" and steady...the compression check low was 125, high 150, indicating ,i presume, good rings and valve guides...what gives??????????
Old 08-13-2001, 12:02 AM
proud owner's Avatar
proud owner
proud owner is offline
Your high compression means the rings and valve-to-head seals are good, meaning your VALVES arent leaking. the guides may very well be the cause..
Pull your plugs, and look at them. there's pretty much only 3 ways oil can get into the cylinder:
1.Bad rings (you'd have low compression)
2.A bad seal around the intake ports (you'd have low vacuum)
2.Loose valve guides.. You wont get a low vacuum reading off valve guides, because the oil is taking up the space and being sucked into the cylinder..
May very well be guides...How many miles on the engine?
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old 08-13-2001, 02:59 AM
rwjr's Avatar
rwjr
rwjr is offline
mileage unknown....on another post, something was mentioned about seals....could it be old and hardened valve stem seals??
Old 08-13-2001, 06:34 AM
DeenHylton's Avatar
DeenHylton
DeenHylton is offline
Yes it could be hardened/broke/missing valve stem seals. They can be replaced without pulling the heads with the right equipment. A defective PCV valve can cause oil consumption also.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old 08-13-2001, 09:05 AM
classic79's Avatar
classic79
classic79 is offline
fordtruckin
53
10-12-2016 03:08 PM
Blown 331
12-24-2009 04:57 PM
1972 Ford Thunderbird 429 V8
12-19-2008 05:42 PM
mgoovaerts
02-14-2004 01:59 PM
schweg2
12-28-2001 01:01 PM
Quick Reply: 429 compression results
