Speedometer driven gear - 15 tooth? - Ford Truck Enthusiasts Forums
Old 02-01-2008, 06:44 PM
fastfarmer's Avatar
fastfarmer fastfarmer is offline
fastfarmer is starting off with a positive reputation.
I'm about to swap in a set of 3.00 gears into my 76 F150. The calculator says I need a 15 tooth driven gear to use with the 7 tooth drive gear on the output shaft of my trans to correct my speedometer. Looking around on ebay I've seen driven gears from 16 to 21 tooth but no 15. Did Ford make a 15 tooth driven gear for the speedometer in my 76 F150?
Old 02-01-2008, 08:30 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Don't think so
check the bottom of this page
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Old 02-01-2008, 08:37 PM
fastfarmer's Avatar
Thanks-guess I'll use a 16 tooth and be happy with "close enough".
Old 02-01-2008, 08:58 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
What size tires are you running?
Old 02-02-2008, 06:41 AM
fastfarmer's Avatar
235 - 75 R15
Old 02-02-2008, 08:59 AM
SRT77 SRT77 is offline
SRT77 is starting off with a positive reputation.
5.0L RPM at 60 mph??? Jonnys.1991 1987 - 1996 F150 & Larger F-Series Trucks 1 01-19-2015 09:21 AM
Speedo Driven Gear Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 07-10-2014 08:35 PM
Which driven gear do I need? big-ugly 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-15-2014 02:50 PM
any sources for cast iron speedometer driven gears? SocialDistortionFan 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-01-2013 01:20 AM
Speedometer Calibration zingerr 1973 - 1979 F-100 & Larger F-Series Trucks 12 04-29-2013 07:35 PM
Tags
15, driven, ford, gear, speedometer, tooth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
