400 to 460 manual trans bellhousings
hey all, I'm swapping a 460 into a 78 manual trans replacing a 400. Question is does the 400 bellhousing need a spacer and if so how thick? Hope to hear from somebody having actually done this particular swap Also did you encounter any problems with throwout bearing or fork? I'm using the 12" diaphragm clutch. Thanks in advance Trey
Well didn't get any good answers so had to learn the hard way,here's what I've found: 1) The 400 and 460 bellhousings are the same pattern but the lengths are different 400=6-1/4",460=6-7/16",This additional length compensates for the thicker flywheel on the 460 which moves the pressure plate and disc back towards the trans. The 460 also uses a special pilot bearing. A 400 bellhousing might could be used but not without modifications to the casting to clear the flywheel and shortening the input shaft bearing cover and possibly the input shaft itself as some cranks might not have enough clearance. Check your engines thrust before and after mounting the trans! I had a friend who did this and burnt up an engine as the crank was forced into the thrust bearing. The automatics interchange with no problem if used with the correct flywheel.trey gorbett/ 78 F250-Bronco Hybrid "SuperBronco" 460,NP435,NP205,Dana60 front,Sterling 10.25 rear,4.10's, 17/40x16.5 GroundHawgs http://communities.msn.com/treys4x4
Tahnks Dennis, I had considered that but I want to retain the mass of the 40# flywheel, I lucked out and found a Lakewood steel bellhousing for a $100 and put that into it, everything matched up perfect after I made some 1" spacers for the bellcrank bracket. Won't hurt having the extra protection (seen some pics of a clutch explosion on one of the other sites,not pretty!).......trey gorbett/ 78 F250-Bronco Hybrid "SuperBronco" 460,NP435,NP205,Dana60 front,Sterling 10.25 rear,4.10's, 17/40x16.5 GroundHawgs http://communities.msn.com/treys4x4
rattrucker
09-29-2013 10:48 PM
mark123456
05-07-2002 01:18 AM
