Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-01-2008, 02:41 PM
Joe Hill is starting off with a positive reputation.
Joe Hill
Will a 1939 front clip fit on a1946 ford pick-up
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-01-2008, 02:45 PM
loholland is starting off with a positive reputation.
Joe, are you talking about just the front sheetmetal or the front frame section or both. There is quite a difference between the frames of the 1939 and the 1946 pickup. Depending on where you are going with your project could require a lot of faberication. Just need more information. There might be someone else that could help more.
  #3 (permalink)
Old 02-01-2008, 02:51 PM
Fenders, hood, grill,radiator, dont really know what else I need. just want to change the look to a 39
  #4 (permalink)
Old 02-01-2008, 03:00 PM
Well Joe, I'm not an expert but I can give my view of it. The 39 car and truck used the same frame and the 46 truck frame was redesigned as a truck in 42 with parallel rails, The cabs changed in 40 and 41. I don't think the reveal along the hood and cab of the 39 won't match with the 46 cab. The cabs from the 40-41 are similar to the 42-47 with few differences. Do you have all the sheetmetal including the cab from the 39? Do you have the 39 frame?
  #5 (permalink)
Old 02-01-2008, 07:31 PM
46fordtruck's Avatar
46fordtruck has a good reputation on FTE.46fordtruck has a good reputation on FTE.
They share a fairly similar cab, in fact, I believe the character line matches up on the belt line between the hood of the '38-'39 and the cowl of the '40-'41 cab. Not a total bolt on, but I believe that you can make it work.
__________________
Gary-
Down to only one, a 1946 1/2 ton
Collector of anything related to 42-47 Ford Trucks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
