oil pump drive
08-24-2001, 01:47 PM
on
oil pump drive
Got a Q? what purpose is the retaining clip serve on the oil pump drive shaft on a 1969 stock 460 engine?
08-24-2001, 02:48 PM
oil pump drive
It prevents the shaft from falling into the pan if you pull the distributor out.
08-24-2001, 07:26 PM
on
oil pump drive
Allows you to remove the distributor without the shaft falling into the oil pan or coming out with the distributor.
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
08-27-2001, 02:50 PM
on
oil pump drive
Thankyou Gentleman for your time and knowledge.
08-27-2001, 06:46 PM
