Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-31-2008, 07:26 PM
falbert is starting off with a positive reputation.
Dtc P0340
I have a 1998 Ford Ranger with a 3.0 V6. 155k on it. The check engine light came on and when I read the error code out I got the infamous P0340 code.
Cam position sensor error. I have already replaced the sensor once (about 10k ago). I don't think that really resolved the problem. I did make sure the shaft was clean as well as the connectors. Does anyone have any suggestions? The plug to the sensors has 2 wires. When I got the part I had to go a Ford dealer, the part cross referenced to the shesor used on a Taurus V6. The parts manger told me it was probley just a bad cross reference.
  #2 (permalink)
Old 01-31-2008, 07:58 PM
Aeroman59's Avatar
Aeroman59 is starting off with a positive reputation.
Post
Do you know if yours is a Hall effect or Variable reluctance synchroniser ? I believe the 2 wire is Hall effect. The code means that the ECU is not recieving the TDC signal from the sensor circuit. The problem can be electrical or mechanical. The synchroniser (drive unit) can fail (the actuating vane can disintegrate or the magnet can fall out of the sensor causing the demise of the synchroniser). If you unplug it & connect up a voltmeter to the sensor plug & crank over the engine, you should get a pulsing reading on the voltmeter (will be low voltage; an analogue meter is best). If this is O.K. check the wiring towards the ECU for breaks or other damage or shorts.
Did you move the synchroniser ? if you did then it's likely that it needs re-timing. The ECU expects to see the signal within certain preset limits if it does not it throws the code. The engine runs on alternative strategy while the light is on.
Well theres some infoto get you going!
ATB Aeroman.
__________________
Green-96, XLT 2wd, 3L Vulcan, from Ontario, Canada
All original powertrain except alternator & starter motor. 292,000 kms & going strong !
  #3 (permalink)
Old 02-03-2008, 08:46 AM
Aeroman59's Avatar
Post More info
http://www.ford-trucks.com/forums/20...placement.html
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
