Does anyone know about D8VE-A2A heads - Page 2 - Ford Truck Enthusiasts Forums
Old 08-03-2013, 11:32 PM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
they are identical heads so no easy upgrade there.
You can run early heads to gain compression if you must.
putting in larger CJ valves and bowl blending as well as working the exhaust side helps on any of the big block heads.
d3ve-a2a Erk Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 06-14-2013 09:37 PM
429 pi? highoctane74 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 04-22-2009 02:24 PM
'79 460 compression ratio 65HTgalaxie Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-13-2008 08:44 PM
460 Casting number redneckchuck New Member Introductions 2 02-11-2007 08:14 AM
D2OE-AB & D2VE-A2A INFO. 79trucksforever Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 02-27-2001 10:00 PM
Tags
460, a2a, d3ve, d3vea2a, d8, d8ve, d8vea2a, ford, head, heads, size, specifications, specs, stock, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
