1976 460
I have a 1976 460 that came out of a Thunderbird that I am putting into my 1979 F-350 4x4. My truck is a 1 ton unit with no pollution control things on it. The 1976 460 has a cross over tube that goes into the back of the heads and then goes into the air pump assembly. Can I run this motor without the air pump and somehow plug the holes in the heads where the cross over tube went to the heads?
Any information will be greatly appreciated.
Craig
Craig
CollinsCD,
Hi - the 460 I put into my F100 had the same kind of emission stuff on it. When I took the heads to the shop to have them planed and checked over (including 3 angle valve job), I had them plug the holes up; the engine runs fine. I've also taken the EGR valve off and am running the Edlebrock RPM manifold. I live in a county where the 1974 F100 is considered a "historical vehicle" and they do not require me to meet emission standards, though...be sure to check with YOUR emmision standards!! Good luck with the 460 - mine runs like a scalded dawg...
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
scottddove
10-10-2007 04:20 PM
jerryh20
04-26-2007 04:23 PM
mud duck
12-04-2002 11:52 PM
