brake lines - Ford Truck Enthusiasts Forums
brake lines
Old 01-31-2008, 05:57 PM
frdkid88 frdkid88 is offline
frdkid88 is starting off with a positive reputation.
brake lines
i need to replace my rear brake line from the master cylinder back. The brake hose to the the cab is just standard brake line but it switchs to a different type right at the cab. I think it is a female fitting on the one end but i don't know what fitting will screw into the master cylinder. Will i have to find the fitting and make the flare myself? Also would they sell this at advanced auto?
Fitting size for Brake master cylinder ports? checksix 1999 to 2016 Super Duty 1 09-14-2012 08:59 PM
Master cylinder trouble shooting crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 18 05-08-2012 12:55 AM
Master cylinder/brake line question ghunt 1987 - 1996 F150 & Larger F-Series Trucks 5 02-09-2009 01:19 PM
Need fitting for brake line to master cylinder Texas 64 Ford 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-19-2008 10:53 AM
brake lines god.boots 1967 - 1972 F-100 & Larger F-Series Trucks 1 04-03-2006 04:20 PM
Tags
1997, back, brake, f150, ford, line, lines, parts, recalls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
