94 460 HP - Ford Truck Enthusiasts Forums
94 460 HP
Old 06-23-2001, 09:05 PM
Ryans460 Ryans460 is offline
Ryans460 is starting off with a positive reputation.
94 460 HP
I have a 94 f-250 with a factory 460. I want to know the horsepower rating from the factory. It is the EEC-IV computer system(i think), and has an E4OD tranny.
Old 06-25-2001, 12:18 AM
xaviar's Avatar
xaviar xaviar is offline
xaviar is gaining momentum as a positive member of FTE.
94 460 HP
I do believe the HP rating on a 94 460 is 230HP @ 3600 RPM. It's torque readings are 390FT/LBS @ 2200 RPM. These numbers were good for the 1987-1994 years. HP and Torque went up in 95.
Xaviar
Old 08-31-2001, 12:04 AM
DeGideo DeGideo is offline
DeGideo is starting off with a positive reputation.
94 460 HP
Old 08-31-2001, 12:13 AM
94 460 HP
I have a '94 F-250 with the EFI460,and the E4OD trans.In 1994, Ford rated the 460 at 245net horsepower at 4,000 rpm,and 400 lb.-ft. of torque at 2,200rpm(with the E4OD).The Superduty(F-450), motorhomes,and stripped chassis vehicles got a 255net horsepower rating,and 405 lb.-ft. of torque.Pre-'94 EFI460s got the 230net horsepower rating, and a torque rating of 390ft.-lbs.
460 carb to 460 EFI jswisc Engine Swaps 15 05-04-2008 07:25 AM
need help 94 F-350 460 detrant 1987 - 1996 F150 & Larger F-Series Trucks 1 02-29-2008 05:45 PM
F-350 460 Electronic computer module detrant New Member Introductions 2 02-29-2008 03:10 PM
1991 460 cams? Justin460 1987 - 1996 F150 & Larger F-Series Trucks 0 12-12-2007 04:17 PM
460 headers Ryans460 Exhaust Systems 1 06-24-2001 09:09 PM
Tags
1994, 460, 4r100, 94, big, block, f150, factory, ford, horsepower, hp, lightning, rating, ratings, torque
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
