Best Battery For The Cold - Ford Truck Enthusiasts Forums
Old 01-31-2008, 01:06 PM
jstnromero's Avatar
jstnromero jstnromero is offline
jstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to beholdjstnromero is a splendid one to behold
Question Best Battery For The Cold
Alright, so I went out to the truck this morning and she was having a hard time starting. I know that the battery is going so I am suspecting that this is the case. I was just wondering what battery you all recommend when it comes to the cold. I know that the CCA are really important and was wondering what works from experience.
Thanks in advance,<O</O
~Jstnromero<O</O
<O
Old 01-31-2008, 06:26 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Well i would get on with at least 675 cca what i run in the 351 and my dad has one with like 800 or something like that cca so taht matter for surely and it sure makes a difference having more cca he has a 302 as well
Old 01-31-2008, 06:47 PM
GlennJ GlennJ is offline
GlennJ is starting off with a positive reputation.
CCA stands for 'cold cranking amps'. Get the battery with the highest cca rating that will fit in the battery tray. A few minutes on the phone should give you a good canvas of what is available in your area. These will also be the most expensive batteries so price may be a factor if the budget is tight.
Old 02-01-2008, 04:00 AM
ford-lover ford-lover is offline
ford-lover is starting off with a positive reputation.
My son install audio system, lights and accessories in trucks and cars. He always tell me that Optima "red top" battery is the best. It is a sealed unit and the lead plates constructions are different that the "traditional" which withstands vibration much better.
Old 02-01-2008, 05:51 AM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Motorcraft BXT-65-850
Old 02-01-2008, 08:26 AM
advocate advocate is offline
advocate is starting off with a positive reputation.
Motorcraft BXT-65-850 - this is what I am using in my truck, it came with the Motorcraft BXT-65-650. They are dimensionaly the same size. It hasnt left me stranded yet even in -35 degree celcius weather.
Old 02-01-2008, 08:54 AM
tkd tkd is offline
tkd is gaining momentum as a positive member of FTE.tkd is gaining momentum as a positive member of FTE.
Optima batteries in my area are twice the price and have no better warranty or expected life in the cold (according to the Optima dealer). By cold I mean it was -15F 2 days ago.
There are only 3 manufacturers of car "traditional" car batteries outside of Optima. Personally, I didn't go with the Optima and haven't regretted it one bit.
Old 02-01-2008, 02:22 PM
jstnromero's Avatar
hmmmm....you guys are coming up with some interesting facts....keep em coming!
Old 02-01-2008, 03:22 PM
Gparcels Gparcels is offline
Gparcels is starting off with a positive reputation.
Do they still make the old Sears die hard batteries? they were pretty good back in the day.
Old 02-01-2008, 05:07 PM
msalyer msalyer is offline
msalyer is gaining momentum as a positive member of FTE.msalyer is gaining momentum as a positive member of FTE.
Wallmart sells a pretty good battery at a pretty good price. I'm running a 850 cca one im my F250 SD.
Old 02-02-2008, 02:26 AM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Exclamation
Consumer Reports top 4 picks;
1)NAPA
2)AutoZone Duralast
3)Wal-Mart Everstart
4)Interstate
Die Hard was voted to be one of the worst!
If it were mine i'de buy a Motorcraft!
Old 02-02-2008, 12:26 PM
jstnromero's Avatar
BlueOvalFitter,
I never thought to look at consumer reports. Thanks for the heads up. I will have to start comparing the cca's of those batteries to see what one will be the best for me. Thanks for all of the info guys,
~jstnromero
Old 02-02-2008, 01:58 PM
wwilson43 wwilson43 is offline
wwilson43 is starting off with a positive reputation.
Rule of thumb on batteries: Get the best warrently and highest CCA that you can, I like the Bosch battery, 3 year full replacement warrently and 96 months pro rated also at 850 CCA
Old 02-03-2008, 02:01 PM
baitmaster baitmaster is offline
baitmaster is starting off with a positive reputation.
Just dropped a Walmart battery into my '05. Out here in the desert batteries dont last very long, so decided 3yrs was enough for the stock one. They had a 850cca that was smaller in size than the HD battery that came with the truck. About $70 and 9yr warranty with 3yr free replacement.
Old 02-04-2008, 01:19 AM
I am in Las Vegas so I know what you mean
1992 F150 Charging Problems digitaldemon 1987 - 1996 F150 & Larger F-Series Trucks 4 01-28-2013 03:19 PM
Temp and Fuel Guages c-how Excursion - King of SUVs 1 09-13-2012 09:10 PM
Offenhauser intake which carberator and kits starwriter Ford Inline Six, 200, 250, 4.9L / 300 10 01-28-2008 02:12 AM
Seems like a dead battery, but it's not..ERR Stroke'NPower 1999 to 2016 Super Duty 16 12-01-2007 06:27 PM
Best Light Truck Tires teg2_nv 1999 to 2016 Super Duty 10 10-05-2006 08:59 PM
Tags
1993, 650, 850, battery, best, bxt65850, cca, dieing, difference, f150, ford, light, make, rated, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
