Defrost = Poor MPG??
I don't think one trip is sufficient information to make a call yet. Call us in 6 weeks again, and give us the MPG's with the setting on "vent".
I start out every morning with defrost for about 5 minutes., after that, I leave the setting on vent or floor heat. If further "defrost is required, you are...1 Driving on a very humid rainy day...or 2 the truck cabin has a a leak and something is damp..like your rug.
Agree with prev post, one trip isn't enough to draw the conclusion that the ac on with defrost is worth 2 mpg.....
And fyi, its a Federal Motor Vehicle regulation from the mid '70s requiring better performance from defrosters.
Metalized glass is probably the better solution, but I'm not sure anyone is still doing this. GM did it on the Olds minivan, but I think the ac was still used for the defrost. Sent that baby down the road so I can't run out and check.
I've got a 93 regular cab long bed 4x4 302/auto and have to make a 230 mile trip home and back from college every once in awhile and twice i used the defrost going home and got 13mpg. Coming back to college i got 17 both times without using the defrost. (Switch was set to off). Dont know exactly why this happens, roads were dry, wasn't very windy either way?
Originally Posted by quicklook2
you should not need defrost for an entire trip.
And I can agree that 150 measily miles is NOT enough to call anything certain. It was merely an observation and a question that came to mind based on what I saw...
Just my $0.02, I've not noticed any difference with the AC on or off in any of my vehicles. I'd agree with Fmr2. I'd also agree with 924X2140 though. I think you need to try that test a few more times to be sure. I'd disagree with the comments about how the AC shouldn't run in the defrost setting though. The AC makes a big difference in humid weather in keeping the windows defogged, espcially in the fall when the temperatures are in the low 40s and and it's humid outside. For a brief period of time, I had two Ford Tempos, one with AC and one without. The Defog setting in the one with AC worked much faster than the one without. As far as older vehicles go, even they ran the AC with the Defog swith on. I drove a '78 Volare for awhile and it's AC ran in when you pushed the Defog button, and I'd assume that 76es and 77s were the same.
Originally Posted by paintslinga2010
So just to get things straight, its OK to pull the plug off the compressor? Mine doesnt work anyway, it just makes an annoying sound every so often with the defrost on.
#29
#30
