Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-19-2001, 12:26 AM
killer4x4 killer4x4 is offline
Garage is empty, add now
killer4x4 is starting off with a positive reputation.
460 Power
__________________
1984 f-250 diesel 6" ez-ride suspension, 35" m/t's.
  #2 (permalink)
Old 08-03-2001, 11:13 PM
Ryans460 Ryans460 is offline
Ryans460 is starting off with a positive reputation.
460 Power
I have a '94 F-250 with a factory 460. It is mostly stock, except for the K+N filter. What I would like to know is what kind of power am I getting from it(numbers). Is there anyone that knows or knows a website that might have the info I need?
  #3 (permalink)
Old 09-01-2001, 08:20 AM
DeGideo DeGideo is offline
DeGideo is starting off with a positive reputation.
460 Power
I also have a '94 F-250 with the EFI460.From the factory,the 460 was rated at 245net horsepower at 4,000rpm.You didn't say which K&N you have. Is it the flat tpye that fits inside the factory airbox,or the open element type which replaces the factory setup? The flat type should give you about 3-5 extra horsepower. A open element K&N air filter should give an extra 10-15. I've tried both.To get the most from you K&N I'd suggest opening up your exhaust with either a larger diameter single pipe, or 2 1/4",or 2 1/2" true duals.Don't go any larger than that with a stock EFI460. I have 3" duals on my truck,but I've upgaded the 460 a lot,too. Good luck,your truck sounds cool!
  #4 (permalink)
Old 04-01-2008, 05:32 AM
four-sixty-power's Avatar
four-sixty-power four-sixty-power is offline
four-sixty-power has a good reputation on FTE.four-sixty-power has a good reputation on FTE.four-sixty-power has a good reputation on FTE.
Someone said my name? Happy April Fools Day!
__________________
Be Careful
Be careful of your thoughts
For your thoughts become your words
Be careful of you words
For your words become your actions
Be careful of your actions
For your actions become your habits
Be careful of your habits
For your habits become your character
Be careful of your character
For your character becomes your destiny
author unknown
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
