About the supercharger, we have a grain vac on the farm that uses 90% of a 4440's pto horse power and torque that that tractor had to give, it actually over heated multiple times in the summer.
They REALLY start to suck power once you start building pressure. The pressure relief valve is set to 16 psi, and the vac relief valve is set to .5 bar.
__________________
1976 F-250 Camper Special - does not run
1977 F-150 Northland Edition - does not run
2002 F-350 Powerstroke
1996 Ranger 2wd 4cyl manual - daily driver
Diamond-T 5-ton truck - does not run (May recieve a DT466 in the future)
