Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 01-31-2008, 06:43 AM
Ranger1F150 Ranger1F150 is offline
Garage is empty, add now
Ranger1F150 is starting off with a positive reputation.
New to BioDiesel questions
I have been reading stuff on this site, which I see you guys refference a lot.
http://www.biodieselcommunity.org/gettingstarted/
I have a basic understanding on how BD is made.
I know I should invest in a appleseed processor and I will soon but first, I am going to make a few batches using the 2 liter bottle method.
Questions
1. How do you drain off the glycerin ?(out of the 2 liter bottle) I am thinking a siphon pump.
2. Instead of a 2 liter soda bottle is there a cheap container that I can buy with a bottom drain ?
3. How do you filter the WVO ?
4. I did not see anything about drying a small batch using the 2 Liter bottle method, any good drying ideas ?
__________________
2002 Excursion limited
1979 Bronco 351M C6
1997 Cobra converitble mustang
1998 Mustang coupe
2000 Focus
  #2 (permalink)
Old 01-31-2008, 08:00 PM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
The instructions that I had said to put your thumb over the mouth of the bottle as you turned the bottle over very gently. I didn't care for that, so I siphoned using fuel line from radio-controlled aircraft. as far as filtering the WVO, I used a strainer. If I were to do that again I woud probably put a coffee filter inside the strainer. Didn't see anything on drying it, only washed it several times. Google "Dr. Pepper method".
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #3 (permalink)
Old 02-03-2008, 12:29 PM
caverjoe's Avatar
caverjoe caverjoe is offline
caverjoe is gaining momentum as a positive member of FTE.caverjoe is gaining momentum as a positive member of FTE.
Questions
Not sure about your area but we get 5 gallon jugs with bottom drains from a pure water store.
  #4 (permalink)
Old 02-03-2008, 02:53 PM
Quote:
cool. Like this one ?
http://www.homeandbeyond.com/prod-0173174.html
Also at the grocery store I found a margarita mix bucket with a drain in the bottom.
__________________
1979 Bronco 351M C6
1998 Mustang coupe
2000 Focus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
