Combustion chamber size???
Anyone out there know how many cc's the chambers are on a 73 460 head?? Also can anyone make a suggestion for a cam that'll produce lots of low end torque?? I've got a 77 F-150, 460/C6. I'm building a new motor for it. I've already got hooker longtube headers, Edelbrock Performer RPM intake, holley 750 vac sec. Looking to get the compression up around 9.5:1. Primary use of the truck is to drag my race car around.
Thanks for any help.
Troy
Troy
73 heads are around 92cc I believe. They should be around 8.5 compression.
chris
79 F-150 Ranger Lariat, 2wd, RC, LB, 460 (intake, headers, cam), C-6(shift kit).
79 mustang (work in progress...its just slow progress)
98 Chevy 4x4 (work truck)
95 Lexus SC300 (wife's baby)
chris
Correct. 72-later heads were opened up to 92cc, as opposed to the earlier 72 and 76 cc heads. This dropped the CR to approx 8.3:1 according to my books.. may be 8.5:1...either way, it's low..
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
ANOTHER 460/C6 @ 365hp/519 lb.ft.
14.36@100.4, 16-18 mpg AHHAAAHAAAHAAA!
J/.c
TxBandit,
According to some head interchange info I have on the 385's, using the 75.8 cc heads off of a 68-71 460 will raise your compression ratio to 9.6 on the 72-73 460.
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Superdave
[font size="1" color="#FF0000"]LAST EDITED ON 06-Sep-01 AT 03:22 PM (EST)[/font][p][font size="1" color="#FF0000"]LAST EDITED ON 06-Sep-01 AT 03:19 PM (EST)[/font]
Sounds like we are both doing the exact same thing to the same truck. I too have a '77 F150 460/C6 that I'm prepping for tow purposes. I'm going to be getting some C8 or C9 heads from a friend that will bump my CR to around 9.5:1. I have the plain performer intake but I have an Edelbrock 750 and will most likely run one of their RV cams(194/204 dur.@.050, 460/480 lift,110*)along with headers. If I can approach 500 ft.lbs., I'll be happy. What will you be towing?
Mike
Mike
dwschmidt
03-20-2010 10:52 PM
joeyweeks06
1983 - 2012 Ranger & B-Series
10-19-2009 08:45 AM
Iantiler
10-14-2008 05:00 AM
Franken-Truck
07-02-2006 08:06 PM
