460 SuperFord Article
[font size="1" color="#FF0000"]LAST EDITED ON 30-Sep-00 AT 08:22 AM (EST)[/font][p]the august edition of Car Craft had a build up of what they called a Smogger engine. It made 491 ft-lbs.@3400RPM(maybe lower RPM becuase the dyno couldn't hold it back)and 433HP@5200RPM ON cheap 87 octane gas
Here are the specs to that engine.
ford 460 block (stock bore)
8.82:1 compression
2" od/3.5" primary headers
35* of full advance timing
Dove-C non cj/scj heads with 2.08/1.65 valves
roller rockers/stifer valve springs.
Cam shaft with .050 lift 220/228* duration
.545/.545 lift
110* lobe center
850 CFM carb on a performer RPM intake
emagine if the compression was bumped a point and a stealth intake we used along with 92 octane gas it should make 1hp per cube
83' Ford Bronco, 6" of lift, 35x12.5x15" thornbirds, and a 230HP I6
84' Ford Bronco 2" DROPPED custom 2X4, Soon to be 460/500hp.
8.82:1 compression
.545/.545 lift
110* lobe center
justshootme84
01-22-2010 08:25 PM
mrlaserboy
15
04-01-2000 10:12 AM
