93 F150 Fuel Always Returns to Rear Tank - Ford Truck Enthusiasts Forums
Old 01-30-2008, 08:57 PM
bluesman2333's Avatar
bluesman2333 bluesman2333 is offline
bluesman2333 is starting off with a positive reputation.
When the tank selector is in rear, fuel returns to the rear tank as expected. When the front tank is selected, it slowly fills up the rear tank but may be also returning to the front tank. My question is that since I don't see a valve under the truck, the in tank fuel pump must have a valve in it that selects the return meaning that the rear tank valve is stuck open. Correct? Is there a way to repair this or is it a fuel pump replacement project?
Old 01-30-2008, 09:03 PM
jr32560's Avatar
jr32560 jr32560 is offline
jr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to beholdjr32560 is a splendid one to behold
on this page see the -(read first post)??--it's on there!!! a pretty common problem -can't remember what it was but you will see it- glad to help
Old 01-30-2008, 09:14 PM
That covers F150's that have the selector valve on the frame rail. The later F150's don't have this valve.
Old 02-02-2008, 07:47 AM
*Bump* anyone?
Old 02-02-2008, 08:03 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Yes you have a bad check valve or shuttle valve inside your rear FDM (Fuel Delivery Module) that is inside your rear fuel tank. The pump is also inside the FDM.
EDIT:
On a 1993 you need to check the FPR (Fuel Pressure Regulator) also as they had a lot of bad ones that year and the FPR will take out these valves.
Old 02-02-2008, 09:46 AM
86caprirs's Avatar
86caprirs 86caprirs is offline
86caprirs is starting off with a positive reputation.
There is a TSB for one way check valves to be installed on your tanks fuel pump(s). I can't remember the nember or what years it covers.
Old 02-02-2008, 07:39 PM
Thanks guys. Sounds like I need to check on the check valves and FPR, (I have the gage but haven't done it on this engine yet). I suppose that one way to check if the problem is fuel returning to the tank though the fuel pump is to temporarily block the line?
Old 02-02-2008, 07:52 PM
subford's Avatar
You have two valves in the FDM. One is the hi pressure check valve that prevents gas from entering the tank from the other fuel pump and hold the fuel pressure after you turn off the key.
The other valve is the shuttle valve and it prevents gas from entering the tank from the fuel pressure regulator when the other fuel pump is running.
The extra hi pressure check valve out side the tank will only work if the hi pressure check valve is bad but will do nothing for you if the shuttle valve is bad.
The FDM.
Old 02-02-2008, 09:35 PM
Ah right! I can compare the fuel pressure bleed off between the two tanks to see if the check is bad. If that is OK, then it's the shuttle valve by default. From the pictures on autozone.com, it looks like the fuel pump assy must contain everything including the shuttle valve, so it must not be a separate item. As far as repairs go, this 150.00 won't be the most expensive one recently!
Old 02-02-2008, 10:40 PM
subford's Avatar
Not sure how you can do that as both the pressure and return line are "T" together and go to each tank.
Yes but not all of the ones autozone sells are good ones. Some are even missing the shuttle valve altogether. I guess they would work OK if you only had one tank.
Example of one brand that autozone sells.
Old 02-02-2008, 11:25 PM
jr32560's Avatar
as noted before --subford you the man!!!-diagrams--love them!!!!if they can't finger them out ?? they need help!!! love ya buddy!!!
Old 02-03-2008, 02:58 AM
@subford, forgot about the fact that you need the pump running. I think at this point I'll just replace the FDM and make sure it's a good brand, complete as it was originally manufactured. Thanks for the help, all.
Old 02-03-2008, 08:15 AM
subford's Avatar
Not sure what I forgot about.
You said you can compare the fuel pressure bleed off between the two tanks and you can not do that with them "T"ed together.
With the lines "T"ed when you shut off the rear pump and the pressure holds you have a bad shuttle valve and if not you have a bad check valve.
And you can only do this if the FDM is 100% OK in the front tank.
Old 02-03-2008, 09:15 AM
No, what I forgot about. Fast typing, bad proofreading.
91 150 fuel dual fuel tanks nann69 1987 - 1996 F150 & Larger F-Series Trucks 1 11-21-2015 04:39 PM
Fuel returning to front take when rear tank selected? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 3 07-20-2015 05:36 AM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 08:07 PM
Fuel Selector Valve? 1986 F-350 w/460 mdm350 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-16-2010 10:52 PM
Strange fuel tank selection issue 88F-150pimp 1987 - 1996 F150 & Larger F-Series Trucks 5 11-02-2007 08:27 PM
Tags
1993, 250, 460, 93, 93f150, bleed, f150, fuel, motor, picture, pressure, pump, selector, side, tank, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
