rocker arm assembly d3ve heads
Hey guys, I just did a set of head gaskets on my 460. Iam now getting around to putting it all back together....Iam stuck on the rocker arms...my heads have bolts, not studs. the rockers are standard, no aftermarket stuff. my book says to torque them...do I?
when I do the pushrods are very tight, arent you sopposed to be able to twist the rod with your fingers?? they should be tight, but loose enough to move with resistance right?? well when I torque them down, they wont budge. and when I tighten them, (not torgueing) I have to tighten them until the rocker seats to the head right? there is a half moon like thing that the bolt goes through, and the rocker rides on the half moon...I dont know what that part is called.
what should I do? should I torque em', run it, and then go adjust them...or loosen the bolt atleast a little??
thanks guys
thanks guys
73 fourxfour
38
02-20-2011 02:55 PM
3TreeGuy
01-07-2010 07:58 PM
