brake bleeding with proportioning valve???
can you bleed the brakes with a vaccuum pump if you used something to hold the brake pedal down so the valve stays open? or do you have to use something to hold open the little nipple thing on the pro. valve
__________________
I now have a gallery will be adding alot of pics soon!
Running again!!!
1979 F250 Ranger 4X4
Vin F26SNEG4150
Dana 60/Dana 44
T18 NP205
3" Body Lift
33/12.50/16.5
400 w/ Edelbrock Intake and 750cfm Carb
Headers-Duals-Flowmaster 40's Dumped Behind Cab Doors etc.
1972 F100 2wd 240ci L6 stock for now
