Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 02-01-2008, 09:15 PM
Mil1ion is starting off with a positive reputation.
This is an illustration of the larger GVWR F250 F350 PPV
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-05-2008, 03:05 PM
kilog55 is starting off with a positive reputation.
ok just for clarification if you use 2 guys to bleed the brakes like in the old days do you have to pull out the bleed valve or does it open on its own?
cause i had the vacuum on it today and opened the bleeder and i didnt get much fluid to come out, no where near what i got out the rear
__________________
I now have a gallery will be adding alot of pics soon!
Running again!!!
1979 F250 Ranger 4X4
Vin F26SNEG4150
Dana 60/Dana 44
T18 NP205
3" Body Lift
33/12.50/16.5
400 w/ Edelbrock Intake and 750cfm Carb
Headers-Duals-Flowmaster 40's Dumped Behind Cab Doors etc.
1972 F100 2wd 240ci L6 stock for now
  #18 (permalink)
Old 02-05-2008, 05:12 PM
The rod has to be pulled to allow "Proper" bleeding of the fronts.
Doesn't matter how many people are involved
  #19 (permalink)
Old 02-05-2008, 05:17 PM
alright i did bleed em they an clear but it is still squishy doesnt get firm till 3/4 way down.
i posted in the brakes section as well about what could cause that issue. if the truck is off and i pump the brakes th pedal gets really firm bu i can still get it to the floor without standing on it. so i assume it is the M/C and possbly the booster
__________________
Running again!!!
Vin F26SNEG4150
Dana 60/Dana 44
T18 NP205
3" Body Lift
33/12.50/16.5
  #20 (permalink)
Old 02-05-2008, 05:20 PM
There is an adjustment between the booster and the Master cylinder that also has to be correct.
  #21 (permalink)
Old 02-14-2008, 09:08 PM
lilbigpony's Avatar
lilbigpony is starting off with a positive reputation.
I just changed all brake lines on the front including calipers and pads, master cylinder etc!!! I have no pedal after several bleeding attempts??? I plugged the new MC to check for leak down/ No leaks!!! I put the rear line on good pedal??? I then put the front line back on, to the floor we go??? Is this the metering bleeder not bled causing this??? I am at a loss and at peaks end with this thing!!! Everthing but that(metering block) has been done!!! Some idiot cut all the brakelines before I purchsed vehicle!!! so the block had no fluid in it for a little while!! Please send me your Opinions even if they have alredy been posted!!!
  #22 (permalink)
Old 02-14-2008, 09:37 PM
You may have a M/C with a faulty primary system seal .....
With the cap off have someone press on the brake pedal and watch for a fountain in the primary reservoir.
  #23 (permalink)
Old 02-14-2008, 10:43 PM
lilbigpony's Avatar
na
If I have a fountain what does this mean?? Sorry if this is a stupid question!!! And as noted earlier! I capped the MC on both outlets and had no leakdown, in fact the pedal was hard and did not budge!! Doesnt this prove the master cylinder to be good?? It is new?? Bleeder valve trouble!!! The system was dry and new lines were installed??
  #24 (permalink)
Old 02-14-2008, 11:18 PM
yes it does .....I must have missed that part.
So,if the hydraulic system is sealed .....it is sealed.
With no leaks, brake caliper pistons extended to rotor and rear shoes adjusted properly and good master cylinder and all corners bled it should be good to go.
There isn't any part of the front brake lines that has a cavity of air in them is there?
I like to know for sure the caliper pistons have extended fully before bleeding.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
