Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-30-2008, 12:35 PM
berry1234 is starting off with a positive reputation.
Warped Rotors at 16K Miles?
Well if I don't have the darndest luck with brakes. I have noticed when stopping at freeway speeds or so a pulsation in the steering wheel that is progressively getting worse. While braking to a stop slowly I feel a go/let go/go kind of action with the brakes. My hunch is warped rotors.
Hard to believe after only 16K of mostly freeway miles. I never washed the car after driving it and I don't ride the brakes. Got a call in to bring it in. Anyone else have experience with warped rotors before?
__________________
2008 Expedition Eddie Bauer 4x2
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-30-2008, 01:14 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
I had an early build Titan and we had the problem from 1200 miles on. I finally got so tired of get the brakes "fixed" by Nissan that I bought Stillens big brake kit to stop the problem. Once the Stillen kit was on, there were no more issues. How bad does the wheel shake??
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #3 (permalink)
Old 01-30-2008, 02:06 PM
Quote:
I have had worse in work trucks, but you go from no movement at all to a decent back/forth shake while the brakes applied. Feels like you are driving over dirt road. Nothing that would pull the wheel out of my hand, more of an annoyance.
__________________
  #4 (permalink)
Old 01-30-2008, 02:38 PM
IQ9 IQ9 is offline
Have the rotors been turned in the 16K? If not you may be in luck as they might turn them and solve the shimmy. Rotors can be warped by over torquing the lug nuts. Have you had any tire work done recently? Just some ideas to help.
__________________
  #5 (permalink)
Old 01-30-2008, 03:37 PM
myexpo02's Avatar
myexpo02 is starting off with a positive reputation.
I have not had that problem with mine...but I do have burning brake smell after a bit of stop and go traffic from the rear rotors. And I don't ride the brakes either and I check everytime for e-brake before I move.
My 02 Expedition never had brake problems and I had 80k when I change the front rotors to cross drilled/slotted type...and another 50k with those on...problem free! I changed the front pads 3 times in 150k and the rears once.
I feel that these brakes (on the 08) are more powerful but....strange burning smell with the slight stop and go traffic. Seems the rear rotors do get a workout.
__________________
2002 Expedition XLT (2wd with 4R100 auto) with 146k...traded on an 2008 Expedition XLT (2wd with 6R75 auto)Heavy tow-package, DVD,18"Chrome Clad wheels,Leather and ScanGauge II.
  #6 (permalink)
Old 01-30-2008, 04:52 PM
No, the tires have not been touched since the dealer rotated the tires 5K ago. I too get that smell when driving down hills, etc and I get out of the truck. Smells like when you get new pads installed. Maybe these pads are not up to the task of these trucks.
__________________
  #7 (permalink)
Old 01-30-2008, 04:56 PM
IQ9 IQ9 is offline
It maybe the pad compound that Ford is using. I have noticed that I have to heat the pads to get them to owrk. Once they heat..man do they stop. I am quite impressed. The smell does not bother me as it is not as bad a EBC's green stuff pads.Those reek. Good luck on the rotors. I hope they can be turned.
__________________
  #8 (permalink)
Old 01-30-2008, 05:00 PM
myexpo02's Avatar
I feel better now...........that I am not only one with "brakes hot" smell. My wife got out one day after I was driving the SUV and she told me....I smell brakes...and then asked...were you hard on the brakes...and I said...no! I also noticed it after she had driven to the store and back.
I guess it's normal?
__________________
  #9 (permalink)
Old 01-30-2008, 05:11 PM
When I take mine in I will ask them about it.
__________________
  #10 (permalink)
Old 01-30-2008, 05:19 PM
myexpo02's Avatar
Quote:
Thank you Sir....I be checking in to see what they tell to you.
__________________
  #11 (permalink)
Old 02-06-2008, 11:43 AM
Got the truck back. They resurfaced the rotors and sanded the pads down. They took off .6mm on the left and .4mm on the right. Brakes great now. As for the smell they said after the first 1,000K it should not be there unless you are braking a lot and hard. Might be worth taking it in.
Also, an interesting read about 'warped rotors'.
http://www.stoptech.com/tech_info/wp...rakedisk.shtml
__________________
  #12 (permalink)
Old 02-06-2008, 12:25 PM
IQ9 IQ9 is offline
Thanks for the update. I'm glad that they could turn your rotors instead of replacing them.
__________________
  #13 (permalink)
Old 02-07-2008, 09:12 AM
myexpo02's Avatar
Thanks for the info.....I have never been a big fan of turning rotors....it just seems that when you take off metal....there is less metal to dissipate the heat created. But thanks again....I am still keeping an eye on mine for a while.
I only have 6500 miles on mine.
__________________
  #14 (permalink)
Old 02-07-2008, 11:42 AM
Yeah, of course new rotors are always best. They didn't take off much material and it's not different than getting new pads, in which case you should turn them as well. Read that article up a few posts. Good info on pad material transfer, etc. I made sure I broke them in right. I am a brake lead foot too, that has to change.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
