computer controlled tranny or not?
I am looking for a 91-96 extended cab 4 wheel drive f150/250. Is there a computer controlled tranny and a non computer controlled tranny,and which trucks had which tranny? which is better? Is there any auto tranny that had problems and should be avoided if possible? thanks!!
on
Early '90's trucks were available with the AOD and C6 which are not electronically controlled, and AOD was 5.0 only. The other tranny's were electronically controlled and the later models were more robust due to updates. In HD trucks(F250 and bigger) this bodystyle and powertrain continued into '97 and part of '98.
I'll ruffle feathers on this post but-the electronic transmissions-e40d well I have them are not too bad-I know here it comes --used in the right contest-heavy hauling and towing click it out of overdrive-not sure about the others-I put close to 200000 on 2 of them in work vans -1994 and 1995-can't complain!!!
nc150
02-08-2006 01:08 PM
95_4x4_jay
10-27-2005 01:26 PM
capt scott
05-19-2002 02:45 PM
