Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Exhaust Systems
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 01-31-2008, 10:21 PM
RangerPilot's Avatar
<-- Private Pilot
RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.RangerPilot has a very good reputation on FTE.
To summarize all of that:
Don't run the tailpipe out below the cab. Trust me, as a pilot who knows the effects of carbon monoxide poisoning, you want the exhaust dump well far away from you and the air you breathe.
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 02-01-2008, 11:47 AM
whitebassbenny is starting off with a positive reputation.
ok everybody, thanks for the advice. I have gaven it a thought and was thinking just do a straight pipe and have it come out in front of the rear wheel. but i was woundering how bad the torque lost would be. If the lost is not "worth it" then i would just did a side pipe off the muffler. I was also woundering if i was to go from the stock 2" pipe up to a 2.25" size pipe would it make it sound any different at all for a side pipe with the muffler and without? I would think it would kinda kill the back pressure w/o the muffer if i was to get a bigger pipe.
__________________
94 ranger 4x4 auto
138,000
31x10.5x15
intake
T-cover
had cherry bomb turbo muffler, flowmaster series 40 (used about 2-3 months make offer clampped on) now cherry glasspack.
2x55w offroad lights in grill
CD with 4 new speakers
500 watt sub w/1500watt amp (has alotta bump in back of seat.)
Tints %20 front %5 back
  #18 (permalink)
Old 02-01-2008, 12:23 PM
kens64 is starting off with a positive reputation.
Quote:
Thats a good thing. The less backpressure the better.
__________________
1964 F100- Gonna see boost
1998.5 Ford Contour- Many mods
JOIN THE NEW MEXICO CHAPTER HERE
  #19 (permalink)
Old 02-01-2008, 12:45 PM
<-- Private Pilot
...thinking just do a straight pipe and have it come out in front of the rear wheel.
Should be fine, enough pipe that you're not just chopping it, which will cause a torque loss due to backpressure loss. Been there, done that. No different than having way too big of a muffler (been there, done that too).
Stock should be 2.25". On my '94 that was stock. If you do have 2" for whatever reason, feel free to run anything up to 2.5" single or so.
Quote:
...To a certain point. Trust me, I've been through this exhaust change with almost the same truck he has. You pull the muffler and have no tailpipe, you will lose torque.
  #20 (permalink)
Old 02-02-2008, 05:51 PM
how would a side pipe be for offroading ? would i have to worrie about it getting broken off on somthing or can i get a pipe that is like a "S-bend" and just clamp it where the muffler goes and have it still come out the back ?
how hard would it be to gut my old cherry bomb muffler and take everthing out of it and use it just for the offset?
__________________
94 ranger 4x4 auto
138,000
31x10.5x15
intake
T-cover
  #21 (permalink)
Old 02-02-2008, 05:52 PM
<-- Private Pilot
You'd have to cut the muffler in half, cut everything out of it, and weld it back together. Not too hard if you're decent at welding.
Side pipes would be okay for offroading. If you wanna run an "S" or any other shape and out the back, that's perfectly okay too. You do what you want, just keep it behind the windows of the cab. It's your truck, as long as you enjoy it, that's what matters.
  #22 (permalink)
Old 02-02-2008, 06:44 PM
godblessmud's Avatar
Jack Daniels if ya please
godblessmud is gaining momentum as a positive member of FTE.
If you just want to blow out the packing then install it and run it hard on some freeway trips for a week then pull it off and shove a pressure washer in it and itl blow out all the fiberglass packing. It still has the cheesgrater in it but now your at almost as good as a straight pipe, with the offset AND if you ever get pulled over for excessive noise you technically have a muffler on.
__________________
Howdy I'm Scott and I'm an adrenaline addict
1990 F150 4X4 XLT Lariat 302 5spd
2000 Ranger 4x2 XLT 244 cid
S_T_G_'_s m_i_n_i_o_n_s:
Public Relations/Recon Dept.
I drink from a cup called fear!
"Hold on tight cause its gunna be wilder than any 8 second ride"
  #23 (permalink)
Old 02-03-2008, 11:06 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
I don't know why I have to repeat this. Backpressure is not a good thing and has nothing to do with torque and is not needed. What you want is velocity in the exahust system. Simply removing a muffler will not have any negative consequences, but an overly large exhaust system will. If your stock pipe is 2.00", you could up that to 2.25" without any penalty, and it will make it louder, but 2.5" is way too large and you will begin to have some torque loss.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #24 (permalink)
Old 02-04-2008, 12:42 AM
TallPaul's Avatar
TallPaul is starting off with a positive reputation.
Quote:
Originally Posted by BaronVonAutomatc
Carbon dioxide will kill you just as dead as carbon monoxide.
So will any gas if it is to the exclusion of oxygen. But Carbon monoxide is especially notorious because it replaces oxygen in your blood stream and thereby blocks the passage of oxygen. Not sure if carbon dioxide works the same way. I've read that greenhouses will increase cabon dioxide levels because it increases plant growth. There is a maximum amount carbon dioxide can be increased and still be okay for people to work inside.
Can't say I have heard anyone complain that a Flowmaster 40 was not loud enough. But straight pipe sounds like the way to go. Probably that and dump just ahead of rear tire. Leave the cat alone though.
__________________
'95 F150 XL, 2wd, 300 I6, 5 speed, 3.08 gear, 157,000+ miles, Flowtech Raptor muffler, driven hard for fun!
'92 Aerostar 3.0 Vulcan V6, auto, 127,000+ miles, Dynomax Super Turbo muffler
www.HonestEdu.org
  #25 (permalink)
Old 02-04-2008, 10:02 AM
Sponsor
Yes, carbon monoxide is not like carbon dioxide. What TallPaul said is correct, carbon dioxide can kill you if the levels get high enough, just like most other gases. Carbon dioxide is more dangerous than other inert gases. But carbon monoxide is actually a poison. It chemically reacts with the hemoglobin in your blood and turns it into something else. The result is that your blood can no longer carry oxygen. And it takes a while for your body to break it down and get rid of it. Over the course of several weeks, multiple exposures can make you sick and tired feeling.
I know this from experience. A truck I used to have had a manifold leak. The gases leaking from it have not yet passed through the cat, and contained elevated levels of carbon monoxide. At the time, my brother was driving the truck to work, and over the course of several weeks he feel victim to carbon monoxide poisoning. While he was ok in the end, he nearly fell to sleep at the wheel on multiple occasions. And get this, this was from the exposure he got on a 15 minute drive to his work. He was always reasonably alert when he left in the morning, but over the course of a couple weeks it just kind of overpowered him. After that, we got the truck fixed. I never would have though a cracked manifold could leak enough of that stuff to have such an effect on someone. A system without a cat can produce a lot more. Normally when you are driving and it is dumping it back behind the rear tire, it does not get into the cab and you are ok.
I'm just trying to emphasize that it is really dangerous stuff and unlike carbon dioxide, which takes high concentrations to harm you, carbon monoxide is actually toxic and stays in your bloodstream.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
