Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-29-2008, 09:34 PM
tcesni is new and has a neutral reputation at this point.
Low beam problem!
I have lost my low beams on both headlights. Its not the bulbs and I don't see in the owners manual any info regarding a fuse. Are these on a fusable link or some kind of circuit breaker?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 01-29-2008, 09:41 PM
sfcwoodret is starting off with a positive reputation.
Many times when you lose the low beams, it is the bulb.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #3 (permalink)
Old 01-29-2008, 10:09 PM
I thought it was unlikely that both bulbs would go at the same time but I replaced them anyway - didn't help. I think that I have a defective relay module located in the power control center under the hood. I don't think I will be able to find a replacement at 11 PM so I will get a replacement tomorrow.
  #4 (permalink)
Old 01-30-2008, 07:05 AM
Now its getting weird. I realized that my Mustang uses the same relay module as the Tribute so I swapped it out but the lights still didn't work. I put the original module back in place and then replaced a tail light that also wasn't working.
Then the low beams worked!! Huh? I can't figure out what is going on. How can a tail light affect the head lights?
  #5 (permalink)
Old 01-31-2008, 07:13 PM
xkpsanit is starting off with a positive reputation.
If I remembeer right, the lights are switched on and off with their ground source. I believe there is a 15 amp fuse (for the hot feed) for each side located @ the left shock tower. I found this out when I put '06 projectors in my '02
BTW I did spell that 3rd word right
  #6 (permalink)
Old 01-31-2008, 07:20 PM
You are correct. I checked both fuses and they were OK. That is when I figured it might be the relay but that wasn't it either. The lights came on after i replaced a tail light that wasn't working. Now the weird thing is that the bulb I replaced looked OK but the new tail light worked and then, magically, so did the low beams. Gremlins!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
